Author Topic: Help! I try to build my project i get servo.c:41: error: 'TIMSK1' undeclared (  (Read 5113 times)
Offline rox2007Topic starter
I am using an atmega 32.
I get this error.
I know it has to do with timing.
servo.c:41: error: 'TIMSK1' undeclared (first use in this function)
I would really appreciate any help
Offline superchiku
  • cooll
The TIMSK register is same for all the 3 timer operations of the atmega32 just the bit address changes for the 16 bit timer the bits 5,4,3,2 of the TIMSK register affect the interrupt of the 16 bit timer, for 8 bit timer TCCR0 BIT 1 AND 0 affect the interrupts and for the timer TCCR2 bits 7 and 6 affect its interrupts...
so instead of using TIMSK1 write TIMSK and only change the bits reffering to the timer your using...
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Thanks for your help but i'm really just a newbie using AvrLib. I dont really understand everyhting you said. I changed timsk1 to timsk and it built without errors, but the part about changing the bits got me confused.
Offline superchiku
  • cooll
Hav you seen the datasheet????
It clearly mentions that the TIMSK register is common to all 3 timer channels
but the bit numbers have been divided between the 3
like u need to change bit 5,4,3,2 in order to affect the 16 bit timer interrupts....
similarly bit 1,0 affect the TCCR2 timer interrupts
sit 7,6 affect TCCR0 timer interrupts
JAYDEEP ...
Thank you very musch
Offline superchiku
  • cooll
no problemo...
JAYDEEP ...
i thought i understood it, but i dont. What are the timer channels. what ports are they on. On the atmega168 i think they were on portd
It sounds like you didn't put timer.c in the makefile.
# List C source files here. (C dependencies are automatically generated.)
#SRC = $(TARGET).c a2d.c timer.c uart.c buffer.c rprintf.c
Or the header file is undeclared.
#include "timer.h"
Sorry for the late reply. All i needed to do was change TIMSK1 to TIMSK, i'm a nub and i'm still learning.Thanks
Offline superchiku
  • cooll
no ull learn well and fast
JAYDEEP ...
Last post October 26, 2007, 08:19:02 PM
by HDL_CinC_Dragon
Last post February 17, 2008, 10:17:38 AM
by silo_xtreme
Last post June 25, 2009, 07:37:31 PM
by justkilintyme
Last post May 29, 2009, 07:21:15 AM
by Tazdevil
