This equation gave me an answer of ~120192Is this a 120k ohm resistor?
Also the 10mF capacitor mentioned does that go between ground and Vin? or ground and "to your circuit"? or ground and Vout?
How can I figure out what wattage my resistor needs to have?
since 'batt' was declared as an integer and initialized to 0, that the max of an integer is like ~65,000
where do you get the value for the 50k resistor and the 10uF cap?
QuoteAlso the 10mF capacitor mentioned does that go between ground and Vin? or ground and "to your circuit"? or ground and Vout?It goes between ground and the voltage you want to stabilize
Started by Jdog Electronics
Started by pomprocker Electronics
Started by vivek9856 Electronics
Started by Truckstop Electronics
