Author Topic: Modded servo with position feed-back  (Read 2296 times)
Offline JAy1stTopic starter
« on: April 23, 2008, 03:03:32 AM »
Hi all,
Has anyone ever heard of modding a servo to get position feed-back ?
I mean, when you tell it to go in a certain position, you have no way of know it's really where you want it, right ?
So what about connecting a wire to the center pin of the pot (inside the servo to make a Voltage divider) and read it's analog value do know the real position?
Will it mess up with the electronics driving it or not ?
Ideas are welcome !
Offline paulstreats
Re: Modded servo with position feed-back
« Reply #1 on: April 23, 2008, 04:11:01 AM »
google "open servo". Open servo is a project which does just this and more with servos.
You can try wiring straight to the pot, but do it in such a way as to be able to remove it easily because you may cause too much noise on the wire which will give the servo circuit false readings (try a low power small signal diode stright on the poit and a wire from that)
Offline airman00
« Reply #2 on: April 23, 2008, 09:30:12 AM »
sure that will work , I think I've seen people do that before
« Reply #3 on: April 23, 2008, 09:42:18 AM »
I've seen open servo before, it's great and too expensive for a basic type of guy like me  ;D
Have any references ?
Offline airman00
« Reply #5 on: April 23, 2008, 12:14:50 PM »
Not really the same.
That servo is fitted by standard with 4 wires....but gives a hint on what can be done..
Tnx for the link....
Offline airman00
« Reply #6 on: April 23, 2008, 12:27:29 PM »
well it will work for all servos , that was just an example
logically, it should work without disturbing anything
« Reply #7 on: April 26, 2008, 06:50:45 PM »
I've seen it done too, just use an ADC on the pot value.
