Author Topic: Charging a NiCd Battery With a NiMH Charger  (Read 2249 times)
Offline airman00Topic starter
« on: April 23, 2008, 09:29:22 AM »
What would happen if I charged this battery   http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=432
with this charger  http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1566
I need to know what would happen to the charger and to the battery itself , I searched google but couldn't find anything about charging a NiCD battery with a NiMH charger, only about charging a NiMH battery with a NiCd charger.
Thanks,
Eric
Re: Charging a NiCd Battery With a NiMH Charger
« Reply #1 on: April 23, 2008, 09:54:39 AM »
I feel very stupid now
After carefully reading the specifications I found out that it can charge NiCD
does this rule that NiMH can charge NiCD apply universally to all chargers?
Offline JAy1st
« Reply #2 on: April 23, 2008, 12:19:56 PM »
I have the RS900 from Lacrosse technology and it does both.
So....
Offline superchiku
  • cooll
« Reply #3 on: April 23, 2008, 12:31:07 PM »
NIcd and Nimh charging is realtively the same and easily done , the problem is with charging li-ion so there compatibility will matter
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline AndrewM
« Reply #4 on: April 23, 2008, 01:46:19 PM »
Actually there is a problem is charging Nimhs with a Nicd fast charger.  Nimhs are designed for much slower charging than Nicds can handle and Nicd and Nimh fully charged states are detected differently between the two charger types. Generally you can charge a Nicd with a Nimh charger, but not the reverse.
There are now chargers and chipsets that can handle pretty much every battery type out there now, including LiPo and LiOn, all with a single circuit.
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
Offline AndrewM
« Reply #5 on: April 23, 2008, 05:30:51 PM »
Last post April 11, 2008, 12:17:23 PM
by superchiku
Last post May 29, 2009, 11:08:40 AM
Last post July 07, 2009, 08:46:14 PM
Last post March 30, 2010, 08:41:55 AM
by billhowl
