Author Topic: Are Servos Powerful  (Read 2233 times)
Offline tomnt12Topic starter
Are Servos Powerful
« on: April 24, 2008, 09:28:39 AM »
im an avid doctor who fan and im planning to build a 1/4 size dalek out of MDF anf HDF. i am planning to build a traingular base with RC to mount it on but i need to know whether servos are powerful enough (then which ones) or if i will need to use DC motors.
cheers
Tom
Offline Steve Joblin
Re: Are Servos Powerful
« Reply #1 on: April 24, 2008, 09:43:28 AM »
some servos are pretty powerful, but they can also get expensive... for something of the size and weight you are looking for, I would go with DC motors.
What are you an avid Doctor of?
« Reply #2 on: April 24, 2008, 09:45:08 AM »
sorry i meant an avid "Doctor Who" fan the british Sci-Fi Drama
Offline benji
« Reply #3 on: April 24, 2008, 11:18:37 AM »
cheap ones (10 $) gethya around 4 kg.cm
good ol' BeNNy
Offline superchiku
  • cooll
« Reply #4 on: April 24, 2008, 11:39:38 AM »
4 kgf / cm is quite a good amnt its like 40 N/cm so it will work
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #5 on: April 24, 2008, 12:09:12 PM »
im probably loking to spend £20 or servos (2 of them) and one cheap one to turn the front wheel for steering
Offline paulstreats
« Reply #6 on: April 24, 2008, 12:38:28 PM »
Maybe think abut using some light plastic to construct it with so it isnt too heavy. hdpe is as easy as machining mdf
« Reply #7 on: April 25, 2008, 12:03:14 PM »
will do i was thinking of aluminium or hdpe for the base and styrene or hdf for the dalek
« Reply #8 on: April 25, 2008, 01:57:38 PM »
http://www.societyofrobots.com/robot_faq.shtml#select_motor
I'd second the suggestion of using DC motors (geared down).
Last post August 19, 2009, 05:35:00 AM
Last post March 22, 2011, 02:45:35 AM
by Graynomad
Last post March 25, 2011, 12:06:07 AM
Last post October 24, 2011, 05:05:32 PM
by Mastermime
