Author Topic: Bare minimum for a robot starter kit  (Read 1345 times)
Offline zackTopic starter
« on: April 26, 2008, 07:06:10 AM »
Hello!
Can the gurus recommend the bare minimum in  a robot starter kit?  I've chosen the picaxe 28x as the MC.  What other parts should I order along with this to get started? Thanks!
Picaxe MC board
Breadboard
Jumper cables
USB
LEDs
Resistors
Capacitors
1 servo
2 motors
Motor driver
IR sensor
Old rc toy for frame
Re: Bare minimum for a robot starter kit
« Reply #1 on: April 27, 2008, 01:46:52 PM »
You will also need a battery, a battery charger, solder, soldering iron, spool of wire (multiple colors), and some photoresistors.
Also good to have a multimeter for debugging circuits.
Check out my $50 Robot tutorial for ideas:
http://www.societyofrobots.com/step_by_step_robot.shtml
Offline ALZ
« Reply #2 on: April 28, 2008, 12:30:50 AM »
Hi: Why are you going to get " 1 servo 2 motors" if you are going to use a RC toy? Have you thought about buying a Pic & pic 2 programmer and not buying a Picaxe MC board. The programmer can now be used as a test tool also.
Hello!
Picaxe MC board
Breadboard
Jumper cables
USB
LEDs
Resistors
Capacitors
1 servo
2 motors
Motor driver
IR sensor
Last post January 07, 2010, 06:19:00 AM
by z.s.tar.gz
Last post October 06, 2010, 09:15:40 AM
by french guy
Last post July 19, 2011, 07:00:53 PM
by corrado33
Last post October 08, 2011, 05:41:16 PM
