Author Topic: which wireless connection should I buy?  (Read 2217 times)
Offline JoeStroutTopic starter
« on: December 25, 2006, 06:08:28 PM »
I need to hook up a simple wireless connection between my laptop and my robot. I'm on a tight budget, so economy is the key feature I'm looking for. Range is not important (I'll never be standing more than a couple meters away), and data rate isn't particularly important either (I'll be sending very small amounts of data). Two-way communications isn't necessary at this point; the robot needs to receive but doesn't need to data.  I should add that I'm in the U.S., and would prefer not to order overseas if I can avoid it.
Any recommendations?
Thanks,
— Joe
Re: which wireless connection should I buy?
« Reply #1 on: December 25, 2006, 07:33:10 PM »
how does your robot communicate?
considered bluetooth?
http://www.societyofrobots.com/electronics_bluetooth_robot.shtml
« Reply #2 on: December 26, 2006, 09:16:26 AM »
That's exactly the question I'm asking.  How should it?
Yes, but I'm not a big fan of it.  First, I've found Bluetooth to be a bit fiddly, even on commercial devices (like my laptop and PDA).  Second, it's expensive — SparkFun Bluetooth modules seem to run about $60.
Someone recently pointed me to this $12 RF link, which is more in line with my budget.  Any opinions on this one?
Thanks,
— Joe
« Reply #3 on: December 27, 2006, 09:36:33 PM »
well, most people use serial, but usb is becoming popular, too. most development boards come with either serial or usb, the latter being a little more expensive.
bluetooth should be reliable, has good range, its high speed, simple to use, and handles interference very well. but yea, its a bit pricy.
looking at the site for the RF link device, my impression of it is that its good, although a bit slow at only 2400bps. note that its only for one way, meaning one only recieves, and the other only transmits. if you get a second pair ($24), you can transmit and recieve data.
you might find this post very helpful
http://www.societyofrobots.com/robotforum/index.php?topic=104.0
« Reply #4 on: January 06, 2007, 02:44:17 PM »
Ive recently heard a lot of good things about the XBee™ ZigBee OEM RF Module ($19)
http://www.maxstream.net/products/xbee/xbee-oem-rf-module-zigbee.php
a tutorial on how to use the XBee here:
http://itp.nyu.edu/~raf275/meshnetworking/XBee/XBee_example.html
Last post April 14, 2007, 09:17:19 PM
by Tsukubadaisei
Last post July 10, 2007, 07:07:05 AM
Last post October 27, 2010, 07:27:20 AM
by bhsmith
Last post June 02, 2011, 03:36:52 PM
