Author Topic: can ir detectors detect heat?  (Read 1385 times)
Offline zackshalacTopic starter
« on: April 28, 2008, 12:05:00 AM »
If i remember correctly, heat is transfered as IR waves, so can you use an IR detector to detect a radiant heat source and move towards it?  Like a photovore, only a heatovore, i was thinking i could build the $50 robot only with IR sensors for a first robot if it would work.
Offline AndrewM
Re: can ir detectors detect heat?
« Reply #1 on: April 28, 2008, 09:00:41 AM »
There are specially designed and calibrated IR sensors designed to do just that.  For a standard IR sensor, I do not believe it would work well, if only because most IR sensors are calibrated to a certain frequency range, or pulse.
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
« Reply #2 on: April 28, 2008, 09:06:32 AM »
if you need to detect heat , check out this sensor
http://www.acroname.com/robotics/parts/R255-TPA81.html
Last post January 26, 2008, 06:19:47 AM
Last post May 21, 2010, 08:15:22 AM
by Hawaii00000
Last post September 04, 2010, 07:47:35 PM
by madsci1016
Last post November 23, 2011, 02:13:35 AM
by adaboy
