Author Topic: car batteries and wheelchair motors  (Read 3649 times)
Offline xboogerxTopic starter
« on: May 16, 2008, 09:17:42 AM »
I've got two wheelchair motors rated at 10.5 amp each and need 24v to make them go vroom. Can I wire up two car batteries in parallel, put two 30amp fuses before each motor and make them work for a test run? or am I risking that I might ruin the motors?
I really want to be able to use these car batteries, I know that they aren't the best to get the job done. but I really don't have the money now to go get the right kind of batteries.
Offline Tsukubadaisei
Re: car batteries and wheelchair motors
« Reply #1 on: May 16, 2008, 09:24:34 AM »
You have to put the batteries in series(because you get 24V which is the correct voltage) not in parallel(because you get 12V). Assuming that those motors work like dc motors I dont think you gonna have any issue using the batteries.
« Reply #2 on: May 16, 2008, 09:40:05 AM »
hey, thanks.
I had the series and parallel flip around. but yes i need 24v. thank you. and thank you google.
http://www.otherpower.com/otherpower_battery_wiring.html
Offline Nyx
« Reply #3 on: May 16, 2008, 09:46:44 AM »
There are two problems with car batteries...
1. Since they're not sealed, they can leak acid if you tip them over too much.
2. They can leak toxic gas when operating, so you shouldn't use them indoors.
Wheelchairs typically use gel cell (deep cycle) batteries.
« Last Edit: May 16, 2008, 09:47:21 AM by Nyx »
« Reply #4 on: May 16, 2008, 10:43:23 AM »
OK, you know of a cheap supplier?
Offline Nyx
« Reply #5 on: May 16, 2008, 04:01:40 PM »
I'm Canadian... I got one at the local Canadian Tire. You can get a 12V deep cycle battery for less than $100.
Offline ribsen
« Reply #6 on: August 22, 2008, 07:35:02 PM »
I know its a late answar but i found this topis interesting :P
xboogerx, what motors do you use? any chance of any schematics or links to the saler?
Im in the need for a good motor as well, but since i dont live in USA, i cant buy from Ebay (most dont ship outside USA)
Last post September 04, 2007, 01:44:42 PM
by airman00
Last post June 27, 2011, 09:20:14 PM
by jrstpeters
Last post August 10, 2011, 04:10:00 PM
by corrado33
Last post February 12, 2012, 11:23:07 AM
