Author Topic: Duplicating the new Futaba robot (hpi)  (Read 1903 times)
Offline bitsimoTopic starter
« on: December 30, 2006, 12:38:21 PM »
hii,
ok firstly i am not a complete new bee, just that i have managed to stay away from micro controllers!
most of my robots till now have been manually controlled ones. ;D
after watching videos of the new futaba robot and many similar ones which dance and are able to roll , i thought its time i started to try to make one!
but after going thru a lot of designs i figured out , firstly its not possible to manually control it!
so i need halp regarding the micro controller selection and all , since i am funded by my university cost is not a major major issue ( a budget betw 0 to 350 $).
 i have been provided with 5 futaba 403PR and 5 of  404PD robot servos for this project, and i have a decant amount of knowledge in C++ and would prefer a USB communication betw the pc and the micro controller.
and could u also help me with any  other majour issues i am over looking.
lastly could u please explain the difference betw normal futaba S3003 servos and these robot servos
Re: Duplicating the new Futaba robot (hpi)
« Reply #1 on: December 30, 2006, 07:33:21 PM »
there are 3 or 4 people on this forum actively building a biped, just search the forum for 'biped' . . .
i am also planning on building a biped, but i havnt thoroughly looked at commercially available controllers yet for this purpose. generally you want something small and light-weight, with as many digital outputs as you have of servos. im probably going to custom design mine as i havnt been too impressed with what ive seen . . .
microcontrollers can do both USB and serial, but serial is generally easier. dont sweat this - if the controller uses serial and your laptop only has usb, just buy a usb-to-serial converter for like $15.
normal servos just take in an input signal, and then moves according to that signal. robot servos have an additional feature - if you move it to a position, it will output a signal to your controller. why is this useful? it makes programming walking gaits as easy as moving your robot around like a doll, then saving the output signal. the commercially available bipeds such as robonova have this feature.
i have never actually done this before tho . . . so im not entirely sure how you command the servo to output the signal or the best way for a microcontroller to read the signal . . . anyone know?
Offline JonHylands
« Reply #2 on: December 30, 2006, 08:42:46 PM »
I would recommend you look at this:
http://www.lynxmotion.com/Category.aspx?CategoryID=67
You would need to buy 2 more servos, plus something to control them.
Or, you could look at this for something simpler:
http://www.lynxmotion.com/Category.aspx?CategoryID=97
- Jon
Last post September 01, 2008, 12:00:45 PM
Last post July 24, 2009, 10:26:38 AM
by Razor Concepts
Last post December 14, 2009, 06:25:18 AM
Last post February 16, 2010, 05:52:27 PM
