Author Topic: 5V micro with 3.3V module...  (Read 1721 times)
Offline TrickyNekroTopic starter
  • 1.6L Peugeot 307 tuner
« on: May 19, 2008, 10:31:58 AM »
First of all thanks in advance for any help provided...
I'm using atmega8535/16 for a single project and I want to use a CYWM6935 from cypress semi...
The problem is that I'm using 5V to power the micro and 3.3V for the module...
I know I can regulate power and such with a resistor and a zener but I have two basic questions...
First... On the command lines on the module... I put a 3.3V zener with what resistor... Think 4K7 is good????
And secondly... will AVR recognize the +3V3 as logic high or I need a transistor for amplification at 5V...
And if I use a transistor noise and transistor switching speed shouldn't be considered????
Thanks again,
Lefteris
Cheers!
Re: 5V micro with 3.3V module...
« Reply #1 on: May 24, 2008, 08:22:01 AM »
You can just get away with ~2 diodes in series (each diode dropping ~.7V), no resistor needed.
Yeap it will recognize it (the datasheet says exactly what voltage is considered high).
Offline Steel_monkey
« Reply #2 on: May 25, 2008, 02:49:03 AM »
CYWUSB6935 datasheet says that it is possible to put more than Vcc on input while current is limited beyond 1 mA. So, you need at least 2 kOhms between mega output and CYW input.
For atmega, "logic high" is 0.6Vcc (read datasheet), that is 3 V, so no additional parts required. However, for additional stability conventional NPN can be used.
        +5
        _|_
        |    |        4K7
        |__|
        |----------------------------------- to ATmega input
        |  collector
                           4K7                               |   /
CYW output        ______             base        |  /
-------------------|______|---------------------||
                                              |                |  _\|   emmiter
                                            _|_                     |
                                           |   |  10-20 K         |
                                            --- GND                --- GND
OOps, I said justwhat Admin has already said.
« Last Edit: May 25, 2008, 03:24:16 AM by Steel_monkey »
« Reply #3 on: May 25, 2008, 02:10:42 PM »
Thanks for the replies guys!
I have some questions here...
I've been doing some search on my own and...
Is a 74HC04 fast enough for this type of communication... It said it's speed it's nearly TTL levelers and it's rated fast speed...
The bad thing is that it inverts the signal but by using two inverters you get the correct one...
Steel_monkey:
Thanks for the schematics... but doesn't this really inverts the signal?!?! If not I guess it's perfect...
And thanks for the search you've done for me...
I have some details I want to share... I'll post later...
Anyways,
Thank you both!
Lefteris
Cheers!
« Reply #4 on: May 25, 2008, 02:56:34 PM »
I founded it!!!
It's on Elektor September 2007!!!
It's only one question here...
Are the signals from a 5V feed micro equal level to a parallel port...
If yes then the only thing needed is some resistors on the channels and some pull down...
I'll post schematics... no copyright here... the guy who did this project offers the schematics for free at his site...
He made a spectrum analyzer at 2.4GHz with the module and he is using the PC's parallel port...
Thanks again,
Lefteris
Cheers!
« Reply #5 on: May 26, 2008, 04:27:32 AM »
Yes, my schematic really inverts signal, I have forgotten this "little problem"  :'(
Last post December 01, 2006, 01:55:27 PM
by JonHylands
Last post May 03, 2007, 01:06:34 PM
by JonHylands
Last post December 01, 2010, 04:10:02 PM
by damanfb
Last post July 04, 2008, 07:44:20 AM
by izua
