Author Topic: $50 battery and circuit problem  (Read 1910 times)
Offline JdogTopic starter
« on: May 14, 2008, 07:06:15 PM »
I have just finished the circuit board, and i'm having some problems. This is my first robot so my soldering isn't that good yet. I'm trying to use the AA battery pack with the 9 volt battery, and it's very confusing. After looking over everything about 5 more times, I've tried fixing things, but still can't get it working.
http://s306.photobucket.com/albums/nn278/Jdog415/Photovore%20robot/ This is the link to the pictures, if someone could possibly take a look and see what is wrong, it would be greatly appreciated.
« Last Edit: May 14, 2008, 07:50:48 PM by Jdog »
Re: $50 battery and circuit problem
« Reply #1 on: May 19, 2008, 07:10:40 PM »
hi
can you try these steps and let us know your results?
http://www.societyofrobots.com/robot_faq.shtml#circuit_debug
« Reply #2 on: May 22, 2008, 11:48:56 PM »
Should my 5v regulator heat up when i plug in the 9 volt battery
Offline alessio136
« Reply #3 on: May 23, 2008, 11:20:07 AM »
yes it does but very low.
if it gets very hot it's becouse you inverted lateral pins. by the way I have not seen the pictures yet. try to control regulator datasheet: VIN goes to the (+) of the battery, VOUT goes to the circuit. central pin goes to (-) of the battery.
Offline Webbot
  • Helpful? 107
« Reply #4 on: May 23, 2008, 06:03:40 PM »
Check out my circuit diagram attached to http://www.societyofrobots.com/robotforum/index.php?topic=3292.msg25198#msg25198
Your regulator shouldn't get that hot. Try unplugging the micro-controller and then re-applying the power. Check out voltages on the IC socket with a meter  - you may have a short
« Reply #5 on: May 25, 2008, 02:17:51 PM »
I love you.
Last post January 12, 2009, 11:49:04 PM
by TrickyNekro
Last post October 11, 2009, 01:12:39 AM
by radhoo
Last post April 27, 2010, 05:44:41 PM
by dellagd
Last post October 25, 2010, 09:49:34 AM
