Author Topic: Servo Repair  (Read 3802 times)
Offline DanCFTopic starter
Servo Repair
« on: December 30, 2006, 09:57:31 PM »
A servo i had made a noise like it ticked over a few gear teeth, and now it just makes noise. Is this permanent damage, or is there a way to repair this problem?
Offline dunk
Re: Servo Repair
« Reply #1 on: December 31, 2006, 05:35:01 AM »
open it up and have a look.
damaged teeth should be pretty easy to see.
i know i have seen replacement gear sets for servos but that will depend on what make of servo you have.
Re: Servo Repair
« Reply #2 on: December 31, 2006, 03:13:53 PM »
I opened it up and the gears are stripped out. I decided its really not worth my time to replace the gears because they will probably strip out again, so I am looking at purchasing better servos with karbonite gears.
The servos I have now are 180 degrees, but the ones I am looking at buying is only 90 degrees. Does anyone know of a tutorial on how to increase the servo range from 90 to 180 degrees?
Offline gamefreak
  • Robo-Enthusiast
Re: Servo Repair
« Reply #3 on: January 19, 2007, 01:05:59 PM »
the gears have a built in stopping point, there is a tutorial on how to modify to 360 degrees but i dont think you can do 180
Re: Servo Repair
« Reply #4 on: January 19, 2007, 02:09:12 PM »
a product you can buy that attaches to a servo for changing angles/torque:
http://www.servocity.com/html/servo_power_gearboxes.html
i havnt seen the instructions to it, but i called and asked and supposedly you have to modify the servo and attach a special circuit for it to work . . .
look into it, you might be able to find out how.
Last post January 07, 2007, 10:11:41 AM
by Electronic_Repair_Guys
Last post June 20, 2009, 07:09:49 AM
by Ryltar
Last post February 24, 2010, 01:31:53 PM
by Hertz32
Last post May 14, 2011, 08:31:10 PM
by kl22
