Author Topic: line follower - PIC16F877A  (Read 5579 times)
Offline wjweijoTopic starter
« on: May 23, 2008, 07:29:14 AM »
I'm using servo motor to control my line follower...so, PICBasic is easier to use...i wanna to ask help on the PICbasic programming...
Re: line follower - PIC16F877A
« Reply #1 on: May 23, 2008, 08:10:08 AM »
wats the question
I know PICbasic very well
to control a servo you do PULSOUT x,y
where x is the pulse from 100-200 if you're running it at 4mhz
and where y is the traget , like portc.a ,etc.
« Reply #2 on: May 23, 2008, 10:37:07 PM »
...i didnt use picbasic before... can i have a sample code, so i can understand clearly..
for controlling the servo, i just know this information:
                 pulse = 1.5ms --> 90 degrees
                 pulse < 1.5ms --> 0 degrees
                 pulse > 1.5ms --> 180 degrees
and...do u know how to write the IR coding by using PICbasic....
Offline Rebelgium
« Reply #3 on: May 24, 2008, 04:00:22 AM »
orgcrime.net
« Reply #4 on: May 26, 2008, 08:46:15 AM »
http://www.picbasic.co.uk/forum/
the pulse number needed changes as the speed of the PIC changes ( like a PIC running at 8mhz instead of 4mhz)
Offline Rebelgium
« Reply #5 on: May 27, 2008, 05:50:46 AM »
Don't make new topics with the same questions, and certainly not in the wrong forum... Keep your questions in this topic.
orgcrime.net
Last post July 11, 2007, 11:12:17 AM
Last post November 09, 2007, 07:48:22 PM
Last post February 03, 2009, 05:02:21 AM
Last post November 26, 2008, 10:58:13 PM
by AdvsNoob
