Author Topic: suction techniques required!  (Read 2692 times)
Offline bitsimoTopic starter
« on: January 01, 2007, 06:13:42 PM »
hii,
i was thinking of participating in a upcoming robotics comp called VOIDS, in this the basic task is to pick up and deposit as many plastic table tennis balls inside a container in under a min.
now i have seen in the same comp. last year everyone used a arm type pickup mechanism , i was thinking to use a suction mechanism to pick up or at least to get the balls in the right orientation , so as to pick it up easily , as most of the teams spend a lot of time in getting their grippers in the right place?
i tried making one with a cpu fan , but it was simply useless and could only pickup  small foam pieces,i think i would need a more heavy duty yet lite system, with a compressors and all, any suggestion for a cheap sys that i can hack or build!
by the way , wonderful job with this site, hope i had found it earlier!
keep it going!
thanks in advance!
Offline JonHylands
Re: suction techniques required!
« Reply #1 on: January 01, 2007, 07:32:22 PM »
A couple things you could try:
http://www.skyhooks.ca/kp.htm#KP44
That would have a little more suction, although you might burn out the motor.
You could also, depending on how big the robot was, mount a cordless handvac.
- Jon
Offline polar bear6
« Reply #2 on: January 01, 2007, 08:32:14 PM »
you can check out what this guy here did.
http://www.ranchbots.com/vac/vac.htm
it sounds like he did the same thing you want to do.
hope it helps!
« Reply #3 on: January 01, 2007, 10:23:36 PM »
considered doing a 8+ finger hand? all the fingers could be actuated by a single pull string, and so the hand grabs the tennis ball at all angles . . .
i couldnt find a pic of it online, but i remember seeing it somewhere . . .
as for vacuums . . . not sure if this is helpful, but might give you ideas:
http://www.birdieball.com/customdocs/pubs/warm-up-range-uber.jpg
Offline Cognaut
  • How do you know that I'm not a robot?
« Reply #4 on: January 01, 2007, 11:41:01 PM »
What about using a spinning brush or pair of brushes that propel the balls into a funnel shaped dust pan that guides them into a bucket?  It would take a lot less power than a vaccuum - just a small motor or two.
« Last Edit: January 02, 2007, 12:41:46 AM by Cognaut »
Last post October 19, 2007, 12:10:55 PM
by hgordon
Last post July 15, 2008, 07:28:37 PM
by BANE
Last post July 19, 2008, 11:50:05 AM
Last post March 21, 2013, 11:09:53 AM
by jwatte
