Author Topic: Pressure Sensor  (Read 2903 times)
Offline rahulisolaTopic starter
  • PhõeniX
Pressure Sensor
« on: May 28, 2008, 08:10:20 AM »
Hi guys....
i'v just finished making a submersible ( an underwater robot ).....
Now, I need to measure the density of the water it is in and send it to a computer wirelessly.....
My Idea: (Addressing the wireless part later) It has a chamber which fills up with water that lets the 'sub' to sink. Now, if the volume of this chamber was known, is there any way to add a few pressure sensors in it and calliberate it to give density, since the volume of the chamber is constant, and the water in it will also have uniform temperature? ( Using Pressure proportional to density, Boyle's Law or something? )
PS: I am new to microcontrollers though I can do coding in C/C++/Java very well. So please help me in this aspect as well...
!$õ
Offline AndrewM
Re: Pressure Sensor
« Reply #1 on: May 28, 2008, 09:27:19 AM »
You can use an air pressure sensor contained in a small flexible bubble of air on the outer wall of the sub.  As you go deeper, the water pressure increases, thus increasing the atsmospheric pressure on the sensor.  If I remember correctly from my diving lessons years ago, every 30ft down in salt water equals one atmospheric pressure level.
Depending on how deep your submersible goes, you will need a pressure sensor that can handle well above 101kPa/14.7psi (sea level pressure).
blog: www.iamwhen.com
  • PhõeniX
Re: Pressure Sensor
« Reply #2 on: May 28, 2008, 09:39:35 AM »
thanx AndrewM....
you are right in saying that i can use air pressure sensor.....
but I need to measure pressures with really high presition......
To explain better, i need to measure the % of presence of salt in water.
With more salt concentrarion, density will increase......(so density sensor).
I think an atmospheric sensor won't give such precise readings (will it?)?
The sub needs to measure only the salt content near the water surface, n doesn't need to go in deep...
So, will the atm. sensor give me desired readings? If yes, how much will it cost, and what should i ask for @ shops (ratings etc)?
!$õ
Offline Brandon121233
Re: Pressure Sensor
« Reply #3 on: May 28, 2008, 01:39:47 PM »
If your trying to measure the concentration of salt in the water just use a resistance sensor, as the amount of ions (electrolytes) in water increases the resistance decreases. Read these http://en.wikipedia.org/wiki/Electrolyte and http://en.wikipedia.org/wiki/Ion_selective_electrode
        —Thomas Edison
Offline SixRingz
  • Bit's and pc's = Robot.
Re: Pressure Sensors
« Reply #4 on: May 29, 2008, 02:57:55 PM »
Are you talking about measuring the density of the water in the tank? Water has a very low compressibility and if I'm reading the graphs I found on the topic right, water density is changing much more with temperature than with pressure. Salt level is also a factor for density if you are building a sub. Maybe a thermal sensor and measuring electric resistance (salt level) would suffice?
You got me really curious though... why do you need the pressure in the tank?  :) What are you building?!?  :o Super-curious...
Grounding things properly means burying them in the backyard...
Offline awally88
« Reply #5 on: May 30, 2008, 09:50:43 AM »
density of water is a constant 998kg/m^3. The pressure water will change however to the formula pressure=density*gravity*height from surface.
If you have a pressure sensor you can just divide by the constant density*gravity and you will get height.
Re: Pressure Sensor
« Reply #6 on: May 30, 2008, 07:36:51 PM »
Wait, density or pressure? Precise to how many decimal places?
I use Honeywell pressure sensors:
http://sensing.honeywell.com/index.cfm?ci_id=16046&la_id=1&catId=79830
Re: Pressure Sensor
« Reply #7 on: May 30, 2008, 08:33:10 PM »
I think he is going about that goal in a very round-about fashion, its a lot easier to take the resistance of that water and match that up to tested values.
        —Thomas Edison
Offline AndrewM
Re: Pressure Sensor
« Reply #8 on: May 30, 2008, 10:16:34 PM »
I think I am lost on what you are trying to accomplish.  If you are measuring the salt level of the water, then pressure would be a bad source of measure.  As Brandon said, resistance might be a better gauge.  Air pressure can change minute by minute practically (i live in Florida where barometric readings can change that fast), and the air pressure will definitely effect the readings gained from a pressure sensor anywhere near the surface of the water.  Once you get down 30-45 feet, it doesn't matter so much.
The only problem with resistance would be that you would not just be measuring salt (Sodium Chloride) content, but salt in the chemist sense of the word (meaning all the chemicals).  But it would still be much more relative than pressure.
Offline kd5kfl
Re: Pressure Sensor
« Reply #9 on: May 31, 2008, 06:19:36 PM »
Kulite brand pressure sensors are accurate to + - .5%. 10 volts in, .100 V out at max rated pressure. So, 4 mV / PSI for a 25 PSI gage. ( don't waste your time; that's the correct spelling )
Sea water increases in pressure 1 Atmosphere - 14.7 PSI - per 33 feet. If you don't plan on going below ~30 feet, a 25 PSI gage should be fine.
You need a very linear amplifier to get that into an easily readable range.
Offline SixRingz
« Reply #10 on: June 01, 2008, 12:34:44 PM »
Density of water is NOT constant. It is depending on temperature and pressure! Just google and you'll see I'm right.
Offline paulstreats
  • Helpful? 20
« Reply #11 on: June 01, 2008, 05:52:07 PM »
It also changes due to impurities such as salt (sea). Chlorine/bromide/calcium(tap water). Though it could be argued that things like chlorine arent fully bonded in water you still have to accept that it is present and that it has a different weight and also its own presence in density to water
Offline awally88
« Reply #12 on: June 01, 2008, 07:20:27 PM »
Hey guys,
Sorry about that, I read through my notes again and I saw that we do just use the constant as an assumption of pure, incompressible water at 300K however as you said it does change as these parameters change.
  • PhõeniX
Re: Pressure Sensor
« Reply #13 on: June 07, 2008, 11:51:27 PM »
hey, thanX for rep, you are right, pressure is too dynamic to measure.......
I think i'l go ahead with the resistance. and as for salt content, i ment all salt(including Mg, Ca, Na etc. etc.) and not just the normal Sodium Salt....
Also, Going deep would'nt be a problem for me...Atleast i'v tested my sub to go 15ft deep in my swimming pool...n i'm sure it can go much deeper...
!$õ
Last post November 14, 2008, 07:36:45 AM
by KicoLogic
Last post July 01, 2011, 11:35:19 AM
by Webbot
Last post August 30, 2012, 10:47:09 AM
by TrickyNekro
Last post March 26, 2013, 09:40:41 PM
by Mastermime
