Author Topic: Basic to C  (Read 2189 times)
Offline vidamTopic starter
  • Robotronics.org
Basic to C
« on: June 03, 2008, 11:02:48 AM »
I'm converting BASIC to C and would like to know how to convert this simple BASIC statement to C:
Dim TempBit As Bit
I'm using AVR Studio, AVRlib and WinAVR.
I tried this statement but it caused a compiler error in C:
static BIT TempBit;
-Melanie
« Last Edit: June 03, 2008, 11:13:18 AM by vidam »
Offline SixRingz
  • Bit's and pc's = Robot.
Re: Basic to C
« Reply #1 on: June 03, 2008, 02:37:57 PM »
I've never used (don't know if they exist even) bit variable types in C. What is the use of TempBit? My suggestion is:
char TempBit;
A "char" is 8 bits (one byte) long. You can then use all the bits separately.
Grounding things properly means burying them in the backyard...
  • Robotronics.org
Re: Basic to C
« Reply #2 on: June 03, 2008, 02:41:38 PM »
char TempBit;
Thanks for the tip. And good question. It is being used as a boolean in the code. So I guess I could just convert it to bool in C and be done with it.
BTW, if I do use a char for the other Bits in the basic code, how do you use the bits separately (i.e. what is the syntax)?
Offline SixRingz
Re: Basic to C
« Reply #3 on: June 03, 2008, 02:58:54 PM »
Well, if you want to use a certain bit you can use a mask. For example to set the second bit, set the char variable to 2:
char TempBit = 2;
This is how TempBit now looks in binary representation:
00000010
If we want to check if the second bit is set we can use a bit mask variable. Let's assume some of the other bits have been set in TempBit, by for example an input port (binary rep. TempBit):
01001010
(73 if you are looking at the decimal representation)
Ok, now we create:
char BitMask = 2;
in binary, BitMask:
00000010
Finally to check the second bit we use logic "and" between BitMask and TempBit:
  01001010 (TempBit)
  00000010 (BitMask)
  00000010
If the result is greater than zero, the bit is set. If the bit is not set, the result will be zero.
  • Robotronics.org
Re: Basic to C
« Reply #4 on: June 03, 2008, 03:06:07 PM »
char TempBit = 2;
00000010
01001010
Ok, now we create:
char BitMask = 2;
in binary, BitMask:
00000010
  01001010 (TempBit)
  00000010 (BitMask)
  00000010
Forgive my ignorance, but I thought char in C could only be a character data type such as the alphabet A-Z. You set a char TempBit = '2'. Confused... How does the compiler interpret a char set to '2' as a number or as a character?
Offline benji
Re: Basic to C
« Reply #5 on: June 03, 2008, 03:25:34 PM »
actually you can define bit variables in C
try this
bit Tempbit;
it works with the compiler i use (codevisionAVR)
good ol' BeNNy
Offline bens
Re: Basic to C
« Reply #6 on: June 03, 2008, 03:48:33 PM »
The char datatype is an integer that is a single byte in size.  It is used to represent characters, which are just numbers (look up ASCII code).  It is probably the smallest datatype you can use on an AVR since registers and RAM locations are all 8-bits in size.
- Ben
Offline paulstreats
  • Helpful? 20
Re: Basic to C
« Reply #7 on: June 03, 2008, 07:26:00 PM »
Some compilers allow booleans or single bit. But i think it ends up wasting the other 7 bits in the byte.
If you are definately going to use more than 1 boolean it might be worth making a struct of single bit datatypes eg.
struct{
       char boolean1:1; //set 1 bit to boolean1
       char boolean2:1;
       char boolean3:1;
       char boolean4:1;
       char 4bits:4; //set 4 bits to 4bits
}booleans
access using:
booleans.boolean1 = 1;
or
booleans.4bits = 0b0101;
Its just a way to utilise all of the available bits. If you just need 1 boolean, than maybe there is something else that you can get away with using the remaining 7 bits on. (the different allocations also overflow independantly too)
  • Robotronics.org
Re: Basic to C
« Reply #8 on: June 04, 2008, 07:53:59 AM »
struct{
       char boolean2:1;
       char boolean3:1;
       char boolean4:1;
}booleans
access using:
or
Thanks this is really neat. It eliminates the need to do bit-masking.
Offline dunk
Re: Basic to C
« Reply #9 on: June 04, 2008, 09:21:31 AM »
hey Vidam,
this has been posted before but it's still useful.
if you want a nice rundown on bit-masking check this article: http://andrey.thedotcommune.com/bitmasking.html
  • Robotronics.org
Re: Basic to C
« Reply #10 on: June 04, 2008, 10:43:16 AM »
hey Vidam,
The article on bit-masking is just what I needed. Thank you dunk. :-)
Last post March 11, 2010, 05:11:43 PM
by rockrobotics
Last post July 05, 2010, 09:16:37 AM
by Freddy4130
Last post August 17, 2010, 12:22:09 AM
by Joker94
Last post September 11, 2010, 10:54:38 AM
by madsci1016
