Author Topic: short in circuit, servo_bus nd sensor_bus  (Read 1170 times)
Offline vishalsaxenaTopic starter
« on: June 05, 2008, 09:24:22 PM »
Hey people
Plz help wid my $50 robot
I m unclear about how to solder the .1uf capacitor Nd I think Ive my circuit
short there if its not there plz tell me hw to find where it is wid help of my multimeter
I tried to do it nd found when i place my mmeter pins on .1uf capacitor I get a beep that means theyr short........help me with this.......
Nd My Servo bus gives reading about 3.56 volt when I place my multimeter's pins on two adjacent pins...... and my sensor bus doesnt give ny value at all......Help!!
One more thing guys......... my battery charging adapter shows setting at 4.5volts
but when i use my multimeter I found out it gives 6.88 volts......
and its output current is: 500mA   is it ok??????
My LED doesnt turn on as I switch on the batteries....... :(
Thanx for reading through my problem
Vishal Saxena
Hey Guys dont just read it please solve my problem too........
admin plz.........if uve time u can also solve my problem.
Im very new to these kinda things so these questions may look kinda dumb to u...... ;)
« Last Edit: June 06, 2008, 12:23:30 AM by vishalsaxena »
Offline sonictj
  • Helpful? 11
Re: short in circuit, servo_bus nd sensor_bus
« Reply #1 on: June 06, 2008, 12:45:24 AM »
If you post pictures of your board it will be easier to identify your problem(s).
1)where are you getting 6.88 volts? is it before or after the 5v regulator.  If you are measuring before the 5v regulator your fine.
2)Are you powering the servo bus with the same power supply as the rest of the board or separately?
3)I would check and make sure all your grounds are common.  That may fix your voltages.
4) As far as the capacitor one lead will be soldered to both pins 20 and 21 the other lead is soldered to pin 22.
    check and make sure you don't have a short between pins 21 and 22 or between pins 7 and 8.
5) like many of us you could have a bad led.  This I would not be worried about.
Hope this helps.  Good Luck.
« Reply #2 on: June 06, 2008, 08:26:51 AM »
Thanx............. sonictj           Ill post my board pics nd yes my 21 nd 22 pins  and 7 and 8 are getting short somehow.........Is it a common problem if yes please tell me the solution if not Ill post the pics...
THANXXXX
« Last Edit: June 06, 2008, 08:37:37 AM by vishalsaxena »
Offline pomprocker
  • Helpful? 16
« Reply #3 on: June 06, 2008, 11:11:10 AM »
« Reply #4 on: June 06, 2008, 11:40:57 AM »
Yeah Buddy I stepped through it...........
Finally I think I ve completed my MCU As Im getting  6volt  on my servo bus and  4.95volt  on my sensor bus..........
My mistake was That I Soldered the programming cable's ( left moast and farthest from the Microcontroller's DIP )
to the other pins And only that has to be left out...........Ill post my picture soon......... So it can help other users whu r getting similar problems.......
See d admin's soldering pics hard....or youll do a mistake.........Admin
is really a great guy........he has such a great interest in these things...........
Thanxxxx admin
CHEERS!!!!!!!!!!
Vishal Saxena
« Last Edit: June 06, 2008, 11:44:02 AM by vishalsaxena »
Last post April 09, 2008, 07:00:33 AM
by derrick_chi
Last post October 13, 2012, 10:47:26 PM
by Corad
Last post July 14, 2008, 10:02:15 PM
by airman00
Last post July 19, 2009, 05:29:50 PM
by SeagullOne
