Author Topic: Problems with DAQ  (Read 1426 times)
Offline BEAMerTopic starter
Problems with DAQ
« on: June 06, 2008, 01:31:51 AM »
hi,
iam doing a new project using data acquision system. here i want to measure the voltage between two points using a bridge network  and then convert them into digital using a DAQ. but i have a problem here...the voltage that iam using has a different ground and the DAQ which iam using has a different ground. how do i overcome this problem.
BEAMer.
Offline Rebelgium
Re: Problems with DAQ
« Reply #1 on: June 06, 2008, 01:39:19 AM »
And you aren't allowed to connect the grounds together?
orgcrime.net
Offline pomprocker
« Reply #2 on: June 06, 2008, 11:08:58 AM »
Ground them together.
« Reply #3 on: June 09, 2008, 06:02:25 AM »
no iam not supposed to ground them together... actually the voltage that iam measuring is the voltage drop inside a camera, and inside the cam the two ground are seperated.. so if i connect the grounds together, i may have the possibility of damaging the camera....
BEAMer
Offline pomprocker
« Reply #4 on: June 09, 2008, 09:58:00 AM »
you're suppose to have a common ground for circuits to work together aren't you?
Last post December 24, 2008, 03:33:35 PM
by fuzzyt
Last post March 29, 2009, 05:18:31 PM
by offy
Last post July 07, 2009, 06:22:05 AM
by kpmcgurk
Last post September 15, 2009, 04:55:50 PM
