Author Topic: High Pulley Ratios?  (Read 4241 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
High Pulley Ratios?
« on: June 08, 2008, 09:26:47 PM »
Hey All,
I'm trying to slow down a motor via belt and pulley (lighter, cheaper, etc..).  The problem I'm running into is that I'm trying to achieve a high ratio (i.e. 20:1, 30:1) and the best differences between 2 pulleys that I have been able to find are 5:1 - 7:1 between sdp-si.com and mcmaster.com.  I'm just wondering if anyone has come across a similar problem and decided to use multiple pulleys or have found the proper products some where?
Offline SixRingz
  • Bit's and pc's = Robot.
Re: High Pulley Ratios?
« Reply #1 on: June 09, 2008, 04:37:03 AM »
What kind of motor are you trying to slow down? It's a bit hard to give a solution without that knowledge. I'm guessing it's big if you are using pulleys and belts to slow it down?
Grounding things properly means burying them in the backyard...
« Reply #2 on: June 09, 2008, 05:47:03 AM »
Hi Six, my bad...
It's a brushless motor with 1500 (max load) to 3000 (max eff) RPM, that i'd like to slow down and get more torque. The shaft is 8mm (actually, it's 8mm with a 1.5mm cut on one side).
Yes, I would like to achieve a 20:1 - 30:1 ratio.
Offline bukowski
« Reply #3 on: June 09, 2008, 11:35:02 AM »
Look at companies like motion industries or boston gear that deal exclusively with power transmission.
For a 20:1 you will probably have to use 4 pulleys.
Two 5:1 pulley systems = 25:1
bear in mind that as the input torque increases, so do the size of the belts and pulleys.
« Reply #4 on: June 09, 2008, 11:39:17 AM »
Bukowsi,
Perfect!  Just the confirmation that I was looking for.
Thank You!  ;D
