Author Topic: Modifying an HS-311 Servo for Continuous Rotation  (Read 29062 times)
Offline RandomskkTopic starter
« on: June 11, 2008, 10:37:29 AM »
Hi everyone!
I'm just getting into robotics, but have been doing all sorts of electronics for a while.
I found the $50 robot tutorial here and am planning on using that to start with.
I got the HS-311 servos the tutorial recommends (plus they're cheapest) and modified them for continuous rotation. I also took a series of photographs for each step, and wrote a small tutorial for this specific servo, since the SoR tutorial is more general and some steps had to be modified slightly for the HS-311.
I cut off the potentiometer tab and glue it down, which is the quickest and easiest solution. The servos are so cheap that it's really not worth trying to make the modification reversible, and this method's therefore the best in my opinion.
The gear that connects to the servo is all in one piece and therefore you can't just pull the connecting part out to stop it turning the potentiometer - you have to actually cut the pot.
You can see the images and read the tutorial on Flickr:
http://flickr.com/photos/randomskk/2569969633/in/set-72157605559564231/
Use the thumbnails to the right to go to the next image.
Let me know what you think!
Thanks,
Randomskk
Offline Maltaeron
Re: Modifying an HS-311 Servo for Continuous Rotation
« Reply #1 on: June 17, 2008, 07:29:27 PM »
I applaud your productive efforts...
I had a lot of 'fun' modifying servos for 180 degrees... Only without good instructions or pictures!
Too bad I didn't record my efforts...
Thanks,
Offline airman00
« Reply #2 on: June 17, 2008, 07:35:34 PM »
Nice pictures!!!
make a page over on the member tutorials page specifically on modifying the HS-311
« Reply #3 on: June 21, 2008, 11:45:44 AM »
Nice! Please make a tutorial!!!
Offline gabe94
« Reply #4 on: December 28, 2008, 12:30:12 AM »
I noticed in the background of your pictures the microprocessor circuit baord. How did you do that Labeling and how did you build that board, i noticed it must have been custom. I know how to make copper board using etchant, but how did you do the good labeling and drilling on top?
Offline RoBoTicS
  • Man is a robot with defects
« Reply #5 on: December 28, 2008, 06:24:50 AM »
This tutorial is going to help everybody thanks Randomskk
Offline geek1
« Reply #6 on: December 28, 2008, 11:34:32 AM »
gabe- that board is the Arduino Duemilanove.
New roboticist and lovin it ;D ;D ;D
Offline jaabot
« Reply #7 on: May 10, 2009, 10:06:06 PM »
This is outstanding! Thank you for posting this. I just modified my servo following your instructions and excellent photos. Thank you.
Offline Strikeskids
« Reply #8 on: August 23, 2009, 08:32:07 AM »
Awesome, works perfectly.
Saved me $12.
 :D ;D :)
Don't take life seriously
Nobody gets out alive anyway.
