Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
So you decided to ditch the servos, eh?
Not quite sure what you mean. The circuit diagram you attached showed 2 connections per motor - where does the '3 connections' come from?
Here is a new schematic I found http://www.freewebs.com/isuru-c/motor_driver.htm but I'm not sure what pins go to the microcontroller.
QuoteHere is a new schematic I found http://www.freewebs.com/isuru-c/motor_driver.htm but I'm not sure what pins go to the microcontroller.The diagram should show that pins 1 and 9 are input 'enable' pins. These give you the third input from your microcontroller and can be pulsed (PWM) to change the speed
Started by Admin Electronics
Started by thibraani Electronics
Started by vivek9856 Electronics
Started by ukesh Misc
