Author Topic: 5V Linear Regulator  (Read 2948 times)
Offline Private ReidTopic starter
  • I love apples ... Yum !!!
5V Linear Regulator
« on: June 20, 2008, 08:00:41 PM »
Enerywhere i go to buy a regulator, the person serving me askes if i would like it to be a negative or positive regulator?!
is there a difference?
which one should i buy?
5v negitive
5v positive
This Post was proudly donated by Sam.
Offline ALZ
Re: 5V Linear Regulator
« Reply #1 on: June 21, 2008, 12:46:01 AM »
Hi Private Reid:  Yes there is a difference. Not to be a smart ass but I don't know what you are builting so I don't which one you need. What it means is if your ground is negative and the other power rail is positive then that's a  positive  regulator. If your ground is  positive and the other power rail negative then it's negative regulator.
Offline Afroman
« Reply #2 on: June 21, 2008, 12:27:28 PM »
The vast majority of the time you want a positive 5V regulator.
For example, going from a 9.6V battery pack down to 5V to power a microcontroller will require a positive 5V regulator, such as the classic LM7805.
Negative regulators are generally only used for creating regulated negative rails for use with certain amplifier circuits.
Last post February 05, 2007, 06:08:09 PM
by JonHylands
Last post December 03, 2007, 12:25:05 PM
by neopj3
Last post February 02, 2008, 07:51:26 AM
by Rebelgium
Last post April 21, 2009, 06:26:29 AM
by msprague
