Author Topic: A math problem in the USB-SERVO2 project  (Read 1356 times)
Offline nickTopic starter
« on: June 22, 2008, 02:28:54 AM »
Hi I am planning to implement the USB-SERVO2 (http://www.societyofrobots.com/member_tutorials/node/25),
but I found a little problem... do the math here:
1. the ATmega8 uses a 12MHz external oscillator;
2. and the Timer1 for PWM generation sets prescaler at 256 (from source code);
3. the PWM should be at 50Hz;
4. Then the ICR1 (aka topcount) is 486.75 = 12MHz/(2*256*50) -> Decimal?!
what goes wrong??
Offline bens
Re: A math problem in the USB-SERVO2 project
« Reply #1 on: June 22, 2008, 03:12:45 AM »
I don't understand what problem you're having.  Are you surprised that you can't acheive exactly 50 Hz when using a timer that's clocked at 46875 Hz?
If you want an exact 50 Hz signal, use Timer1 in phase-correct PWM mode with a prescaler of 8 and a top count of 15000 (or maybe 14999?).
- Ben
« Reply #2 on: June 22, 2008, 06:47:13 AM »
Thanks Ben.
I am just wondering why it uses 12MHz and 256 prescaler to generate a not-so-accurate top count.
AVR-USB runs fine with 12,16..MHz.
Offline dunk
« Reply #3 on: June 22, 2008, 08:32:41 AM »
hobby servos don't need to be at exactly 50Hz either. the actual pulse duration has far more effect than the exact frequency.
« Reply #4 on: June 22, 2008, 09:44:27 AM »
Thanks dunk.
Last post August 10, 2008, 05:40:36 AM
by airman00
Last post April 11, 2010, 05:47:37 PM
by tim_wang
Last post December 12, 2010, 01:22:04 AM
by Nasser_Abu Dhabi
Last post June 18, 2011, 02:56:51 AM
by Mike11
