Author Topic: Programmer help 50$ Robot  (Read 1380 times)
Offline ljoseTopic starter
« on: June 24, 2008, 01:27:29 AM »
can we use the same programmer for ATMega16 and ATMega8?
The datasheet for my programmer says
Pin 1 AVR Mega 16 Pin 6 (MOSI)
Pin 2 AVR Mega 16 Pin 7 (MISO) and so on..
basically it seems like it's not intended for the AVR MEga 8 I'm using
i also tried 'Write All',
The unknown device error...msg appeared - I "ignore" d it
As Pony Prog contd writing (0%..15%..95%) the LED attached to the IC flashed
Finally when it had almost verified Pony Prog ends with "Write Failed"  :'(
**I was wondering what the flashing LED signifies
 the programmer is powered up correctly...the serial port is fine...the LED's connected correctly...and...? ***
« Last Edit: June 24, 2008, 02:12:50 AM by ljose »
Offline silent069
Re: Programmer help 50$ Robot
« Reply #1 on: June 27, 2008, 05:53:27 PM »
if you could id definitely  order the avrispmkII programmer and u can save urself a ton of trouble!
if not, try building this and see what happens. Very cheap to make, i managed to build one in about 30 mins. http://www.instructables.com/id/EXIM2VJJ51EUKIKWDF/
« Reply #2 on: July 03, 2008, 06:31:08 AM »
Finally found the solution...I didn't write the required Security and Configuration bits to the IC...
Offline izua
« Reply #3 on: July 03, 2008, 11:29:56 AM »
*severe eye bleeding, ignoring thread :P*
Last post February 26, 2009, 05:03:44 PM
Last post March 29, 2010, 02:48:39 PM
by Conscripted
Last post January 17, 2012, 07:02:01 AM
Last post August 17, 2012, 11:36:53 PM
by Atak
