Author Topic: Looking for the right sensor  (Read 1284 times)
Offline ahabTopic starter
« on: June 26, 2008, 07:53:19 PM »
I'm building an autonomous rover (think DARPA 2005 on a 1/8th RC truck).
I'd like to get a fairly comprehensive scan of the ground in front of my bot to find a path. 3+ meter range and covering 135 + degrees, Sensors go from an array of 5 $40 IR sensors to $1300 Hokuyo scanning sensors.
I thought about making an array of IR sensors, but even using the 5 beam Sharp sensors I cost and wires would add up pretty quickly.
Is there a middle ground that I'm not finding?
« Last Edit: June 26, 2008, 08:12:24 PM by ahab »
Offline AndrewM
Re: Looking for the right sensor
« Reply #1 on: June 26, 2008, 09:32:44 PM »
Using a single or perhaps two sharp IR sensors (or sonar range finders) on a servo or two and sweeping the area.
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
« Reply #2 on: June 26, 2008, 11:30:58 PM »
if you feel like you are up to the challenge  , use two cameras and do image processing
Last post March 26, 2008, 03:06:36 PM
by AndrewM
Last post May 06, 2008, 01:59:18 PM
by TrickyNekro
Last post July 31, 2008, 08:17:54 PM
by Luco
Last post September 16, 2008, 01:24:12 PM
by Gertlex
