Author Topic: programmer for$50 robot  (Read 1675 times)
Offline vishalsaxenaTopic starter
« on: July 01, 2008, 09:06:12 AM »
Hey people I have this  six pin dip programmer how do i program my $50 robot MCU with 10 pin male headers.......???????????
Offline bukowski
Re: programmer for$50 robot
« Reply #1 on: July 01, 2008, 10:23:16 AM »
you have to match the pinouts of your programmer to the pinouts of the header. Look at your programmer's datasheet.
« Reply #2 on: July 01, 2008, 10:24:14 PM »
Well my programmer pinouts dont match as programmer has 6 pins ( female ) and MCU has  5*2  pin ( male )..........
Can I make other programming board just to program it with this programmer.......
and then use the same Atmega8L in my $50 MCU ????????
I found this site      http://electronics-diy.com/avr_programmer.php
and I have this same programmer ( given on the above website) ....... having six pins ( female )
but programmer board for it is different......
If i make this board and program it will it work on $50 robot???????
Admin If you can reply please do.....
Thank you
Vishal Saxena
« Last Edit: July 01, 2008, 10:26:35 PM by vishalsaxena »
« Reply #3 on: July 02, 2008, 01:15:33 AM »
Help me please........ :) ::) ::) ::) :-[ :-[ :'( :'( :D
Offline bukowski
« Reply #4 on: July 02, 2008, 11:15:34 AM »
First off, let me tell you I have never done this, and I am assuming that everything in the tut is correct.
It should work fine, just sub in the 1x6 programming header in place of the 10-pin, and make sure you connect the signals as it is drawn.
Also, it appears that you will need an 4Mhz external oscillator for it to work.
« Reply #5 on: July 17, 2008, 06:27:12 AM »
All the instructions are in the tutorial, just read it carefully again.
Nope, no external oscillator is needed.
Last post February 26, 2009, 05:03:44 PM
Last post March 29, 2010, 02:48:39 PM
by Conscripted
Last post January 17, 2012, 07:02:01 AM
Last post August 17, 2012, 11:36:53 PM
by Atak
