Author Topic: Inexpensive brushless DC motor controller  (Read 12046 times)
Offline Steve JoblinTopic starter
« on: July 01, 2008, 10:56:23 AM »
I've been searching for a cost effective brushless DC motor controller that can control a 24V 250W motor via PWM... The only ones I have found seem to be hundreds of dollars... does anyone know where I can find an inexpensive one, or does it make more sense to make it myself?
Offline izua
Re: Inexpensive brushless DC motor controller
« Reply #1 on: July 01, 2008, 12:02:32 PM »
At that power you shouldn't expect something cheap, you know.
Offline BANE
  • E=roboticsC^2
« Reply #3 on: July 01, 2008, 07:27:53 PM »
I just purchused this one yesterday, I'll tell you how it works then it comes in.
http://www.robotshop.ca/home/products/robot-parts/motor-controllers/brushed-motor-controllers/all-brushed-motor-controllers/solarbotics-l298-motor-driver-kit.html
Bane
I never knew they made a board for the L298 , i've always used the chip by itself
Offline BANE
  • E=roboticsC^2
« Reply #4 on: July 01, 2008, 07:45:51 PM »
Bane
I was about to have one custom made for like $50 before i found this one
Bane
Offline bens
« Reply #5 on: July 01, 2008, 07:52:58 PM »
The L298 is not a brushless motor driver.
Offline BANE
  • E=roboticsC^2
« Reply #6 on: July 01, 2008, 08:04:27 PM »
Whoops, should have read the post :D.  Your right, does he want a Stepping motor driver or something?  If not, i'm of no help :P
Bane
Offline hgordon
  • Helpful? 7
« Reply #7 on: July 01, 2008, 09:27:55 PM »
Do you need forward & reverse, or just a single direction ?  A 10A controller shouldn't cost too much, though I'm not 100% certain about the voltage - the brushless controllers with which I'm familiar generally aren't used above 15V, e.g.
   http://hobby-lobby.com/speed-control.htm
Surveyor Corporation
  www.surveyor.com
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #8 on: July 02, 2008, 02:35:51 AM »
Bane
L298 is not a stepper motor driver either.... It's a dual H-bridge... if you want to connect a stepper interface it with L297 to have stepper control...
But L298 can be used for brushless motors... as far as you have some other goodies on board....
To make a brushless motor controller you need both extended programming and electronics knowledge...
Lefteris
Cheers!
