Author Topic: uart / hyperterminal actin funny  (Read 2548 times)
Offline pomprockerTopic starter
  • Helpful? 16
« on: July 01, 2008, 11:37:12 PM »
I recently had to rebuild my computer's software and its never the same after...
I'm using the BlueSMiRF Gold on my $50 robot and when connecting to it in hyperterminal on COM3, its not giving me the options to select baud rate and all that, its just connecting right away, and i'm seeing nothing being printed on the screen. (I should be seeing the sensor readings run down the screen)
Offline Gertlex
  • Helpful? 23
Re: uart / hyperterminal actin funny
« Reply #1 on: July 02, 2008, 01:10:34 AM »
I'm not 100% sure what you're doing, but what might work is to disconnect the connection (in hyperterminal) and then click the properties button or whatever (again, in hyperterminal).... Might give you a lead.
I
  • Helpful? 16
« Reply #2 on: July 02, 2008, 09:44:08 AM »
It's not offering any properties for the COM port associated with the connection, when it used to.
« Reply #3 on: July 04, 2008, 10:11:48 AM »
What OS are you using? Did you change the OS?
edit: said something irrelevent again . . .
« Last Edit: July 04, 2008, 12:02:28 PM by Admin »
  • Helpful? 16
« Reply #4 on: July 04, 2008, 11:51:05 AM »
Windows XP Service Pack 3.
Its Hyperterminal 5.1
  • Helpful? 16
« Reply #5 on: July 04, 2008, 12:10:47 PM »
The UART works perfectly in the Mac OS X (Tiger) Terminal program running the screen command.
I need this to work in Hyperterminal so that I can disconnect and connect with the fboot17.exe
« Last Edit: July 04, 2008, 12:11:35 PM by pomprocker »
Offline izua
« Reply #6 on: July 04, 2008, 12:25:37 PM »
Try altering settings in hardware manager.
Maybe it has a fixed baudrate, and the OS is reading at the wrong one.
  • Helpful? 16
« Reply #7 on: July 04, 2008, 01:24:34 PM »
yes I set the baud perfectly in hardware manager to 57600 to the applicable com port.
« Reply #8 on: July 19, 2008, 02:10:34 PM »
Does your multimeter/oscilloscope detect any signals?
  • Helpful? 16
« Reply #9 on: July 20, 2008, 03:06:56 AM »
it's working perfectly through the terminal on my mac os x. but hyperterminal is giving me problems after rebuilding my computer. its win xp sp3 with hyperterm 5.1
« Reply #10 on: July 20, 2008, 07:16:56 AM »
What about RealTerm or Teraterm? But I suspect you'll still have the same problem . . .
I'm still using sp2, didn't want to 'fix' something that isn't broken . . .
Last post August 12, 2007, 08:06:51 PM
Last post April 18, 2008, 03:36:29 PM
by paulstreats
Last post July 24, 2009, 12:04:24 AM
by darm dzzle
Last post December 07, 2009, 03:04:01 PM
by waltr
