Author Topic: Creating a battery charger  (Read 1775 times)
Offline boybTopic starter
« on: July 03, 2008, 08:44:50 PM »
Is 500mAh ok for a battery charger or is it too high?
I have an adjustable charger that I can change the voltage to match the battery pack.  Is it ok if the voltage is +/- 1V of the battery pack you are supplying it to? Should I favor the +1 instead of the -1?
Re: Creating a battery charger
« Reply #1 on: July 20, 2008, 05:18:47 PM »
500mAh? or 500mA? :P
Both are fine.
To charge a 6V battery, you'd typically wanna use something around 7V+. A fully charged 6V battery is *never* 6V, but some voltage higher than that.
« Reply #2 on: July 30, 2008, 12:15:26 AM »
When I charged the battery pack I did it with an 8V supply (closest to >6V I could find) and 500mA.
After the battery pack supplied 7V.  Is this normal at all?  It's a NiMH battery, I thought their voltage was supposed to be relatively constant...
« Reply #3 on: July 30, 2008, 06:36:48 AM »
yeap, pretty normal
