Author Topic: Motor Driver  (Read 1394 times)
Offline R.O.B. 2.0Topic starter
Motor Driver
« on: July 04, 2008, 08:50:01 AM »
I recently built two H-bridges for my robot. :-[ :-[ I found this motor driver on spark fun but I can't figure out what goes where from the data sheet. Could someone help.
http://www.sparkfun.com/commerce/product_info.php?products_id=315
Offline Steve Joblin
Re: Motor Driver
« Reply #1 on: July 04, 2008, 09:29:48 AM »
Regulated +5 Volts to pins 1, 9, and 16
Microcontroller Control signals to pins 2, 7, 10, and 15
Motor "A" to pins 3 and 6
Motor "B" to pins 11 and 14
Voltage supply for motors to pin 8
Ground to pins 4, 5, 12, and 13
You control Motor "A" as follows:
To halt motor, make pins 2 and 7 both low, or make pins 2 and 7 both high
To make motor spin in one directon, make pin 2 high and pin 7 low
To make motor spin in the other direction, make pin 2 low and pin 7 high
You control Motor "B" as follows:
To halt motor, make pins 10 and 15 both low, or make pins 10 and 15 both high
To make motor spin in one directon, make pin 10 high and pin 15 low
To make motor spin in the other direction, make pin 10 low and pin 15 high
Last post October 06, 2008, 04:24:36 PM
by javafiend
Last post March 01, 2010, 11:59:58 AM
by little-c
Last post May 14, 2012, 06:56:50 AM
by mstacho
Last post December 02, 2012, 03:35:43 PM
