Author Topic: Need help cutting metal  (Read 2397 times)
Offline pomprockerTopic starter
  • Helpful? 16
« on: July 06, 2008, 11:24:26 PM »
I bought one of these and i need to figure out how to cut it to length:
http://www.drillspot.com/products/376896/Approved_Vendor_5MY72_Low_Carbon_Steel_Threaded_Rod
I have access to a hand held jig saw, a hand held drill, and a dremel.
Offline JonHylands
Re: Need help cutting metal
« Reply #1 on: July 07, 2008, 02:04:25 AM »
You need a hack saw to cut something that size. You might do it with a dremel, but you'll probably completely mess up the threads.
The best thing to do is thread on a couple nuts, and then cut it to length. When you unscrew the nuts past the cut, they will help clean up the threads where you cut it. You may also want to touch up with a file once you've cut it off.
- Jon
  • Helpful? 16
« Reply #2 on: July 07, 2008, 09:43:04 AM »
Thanks Jon. Any special blade on the hand held hack saw required?
Offline Scheda
« Reply #3 on: July 07, 2008, 10:50:29 AM »
You might want to surround the spot where you plan on cutting with the nuts. That way you've got a nice and solid guide to go straight down and you don't really risk a crooked cut.
  • Helpful? 16
« Reply #4 on: July 07, 2008, 10:56:30 AM »
Yes..very good idea
edit: ok i got a hacksaw blade that says it can cut threaded rod. i couldn't find any nuts this type it seems 3/8-16 is more popular than 3/8-24.
« Last Edit: July 07, 2008, 02:42:10 PM by pomprocker »
Offline Cotowar
  • Ubuntu for Humans
« Reply #5 on: July 08, 2008, 11:33:16 PM »
another option, however retarded it might be, is to sand it off.
is it bad that that is what I thought of first?
--Cotowar--
« Reply #6 on: July 13, 2008, 09:44:25 AM »
after messing up the threads, i've used a hacksaw to *fix* the threads . . . just run the blade along the threading . . .
edit: I also use a metal file occasionally for this. Kitsune's idea below is really good too.
« Last Edit: July 15, 2008, 09:16:48 PM by Admin »
Offline Kitsune
« Reply #7 on: July 14, 2008, 10:05:12 PM »
1. Put a nut about 10 threads up from the cut point.
2. Make the cut.
3. Take the nut off the over the cut part.
   (this realigns the threads and takes off any burs made bu cutting.)
Offline Trumpkin
« Reply #8 on: July 15, 2008, 12:51:21 PM »
A sawz all would get the job done too.
Robots are awesome!
Last post March 26, 2008, 05:43:13 AM
by sdk32285
Last post November 08, 2009, 12:57:04 AM
by Karl38
Last post June 24, 2011, 03:14:33 PM
by nickc
Last post October 04, 2011, 11:52:10 AM
by Anoroc
