2
Author Topic: Ultrasonic conections  (Read 1703 times)
Offline PortugalTopic starter
« on: July 08, 2008, 01:57:55 PM »
I have to built a robot that fires to an obstacule. The problem is that I want to include it in a 40$ Robot. The robot should continue "walking" when it finds a target, but i dont know how to make the connections between the ultrasonic sensors and two small motors that will fire a ball. The emissor and the receptor are like these:
Emissor
Receptor
First of all: How do I mount the sensors?
Second: Do I need some chip (Like l293d)?
Third: What materials do I need?
Fourth: What connections do I need to do?
Thanks.
Re: Ultrasonic conections
« Reply #1 on: July 08, 2008, 02:04:41 PM »
do you want to use a microcontroller or not?
if not then you would need a comparator , motor driver , and either IR or ultrasonic sensors.
Look those topics up. I even wrote about some of them on the members tutorials page.
« Reply #2 on: July 08, 2008, 02:25:50 PM »
I want to use a microcontroller.
« Reply #3 on: July 08, 2008, 02:48:42 PM »
ok so you want to spend a total of 40 dollars only? this is very hard to do , expecially if you live outside the US
now then
you need two servos  = around 20 dollars
one ultrasonic sensor = around 20 dollars
one sharp IR sensor = around 12 dollars
one homemade IR sensor = around 3 dollars
one microcontroller
one battery pack
now to launch a ball you either use a motor to make a catapult or an air pump
Also, do some research . We can't just tell you exactly how to build your robot. You need to know what your are doing yourself .
Come back with more specific questions and you'll get better replies
« Reply #4 on: July 20, 2008, 06:23:23 PM »
The $50 Robot is what you want, as it uses a microcontroller. The $40 Robot is hardwired therefore can't be programmed.
