Author Topic: Cheap Linear Servo?  (Read 13090 times)
Offline xamirxTopic starter
Cheap Linear Servo?
« on: July 13, 2008, 05:11:18 AM »
Hi everyone
I need a linear actuator for my thesis project. I need to implement a robot eyeball system with 'tendons'. the actuators from Firgelli.com would be perfect, the only problem being that they cost about $60 each! Is there a much cheaper alternative? Or is there a way to convert a standard servo to linear motion?
Somebody told me to check out old 3.5 Floppy drives cause they have a linear mechanism of sorts? Are there any other 'scrapyard' type devices where i can salvage a linear servo or actuator?
Amir
Offline BANE
  • E=roboticsC^2
Re: Cheap Linear Servo?
« Reply #2 on: July 13, 2008, 10:03:10 AM »
You could use the device in a CD player that moves the laser back and forth,  maybe you could attach a linear potentiometer on it somehow and use a servo h-bridge.
Bane
Offline Commanderbob
  • Embeddedmicro.com
« Reply #3 on: July 14, 2008, 07:17:50 PM »
You can always attach control rods to servos. That lets you push/pull with them. Almost every RC vehicle uses them for turning to some kind of motion. Here is a picture of one.
Justin
Offline Trumpkin
« Reply #4 on: July 15, 2008, 01:18:44 PM »
try ebay.
Robots are awesome!
Offline emmannuel
« Reply #5 on: July 15, 2008, 02:06:06 PM »
OMFG I've been looking for solutions like those that were economical and worked.....
The linear actuator using the DC motor is awesome.. now I feel dumb for never thinking of those ideas :P
Offline bulkhead
« Reply #6 on: July 16, 2008, 01:04:40 AM »
Control rods with servos will probably be the easiest and cheapest way to do it using standard $10 servos.  Look at this picture:
The motion of the rod is essentially linear, especially if you just use it to pivot a joint that only has 1 degree of freedom (like a door hinge).  This route will require some careful thought about where the pivot points are because the available pushing/pull force of the servo is a sine/cosine function, where the servo could end up with zero mechanical advantage.  If you go this route go to a hobby shop and look at the steering mechanism on any RC car.  You will need "rod ends" (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHGB7&P=7) from any hobby shop carrying RC car parts and a ~1/8" threaded rod from any hardware store (cut to the length you need).
Last post February 25, 2008, 07:16:51 AM
by Trikky2
Last post July 02, 2009, 08:39:10 PM
by Razor Concepts
Last post January 23, 2010, 07:34:03 AM
by Antonb
Last post March 29, 2010, 05:50:17 PM
by Antonb
