Author Topic: 50$ Robot Resistor  (Read 2083 times)
Offline MechanoManTopic starter
50$ Robot Resistor
« on: July 17, 2008, 02:18:51 PM »
Hello all. I am currently working on soldering my board for my 50$ robot's brain. In the tutorial it says that a resistor is connected to the LED (roughly underneath the servo outputs on the board). I was wondering which resistor is suppose to be soldered into this spot as the list of parts suggests buying two types of resistors, and the ones I bought do not have the same colors as the one featured in the pictures.
Thanks.
Offline dsheller
Re: 50$ Robot Resistor
« Reply #1 on: July 17, 2008, 03:57:37 PM »
What color bands does your resistor have on it? Make sure you name them in the order they appear as it is important... or read this link:  http://www.bcdxc.org/resistor_color_codes.htm .
I am not sure what the tutorial says to use, but a value like 330 Ohms is good for a current limiting resistor on an LED... assuming you're using a battery.
« Reply #2 on: July 18, 2008, 01:33:56 PM »
Thank you. Your advice on the 330 ohm resistor used with a LED was very helpful. The resistor I have is a 340 ohm, and I discovered the purpose of the other resistors (1.6 kohm) I have.
Offline Pierre
« Reply #3 on: October 01, 2009, 08:03:06 PM »
This is great that you know what the 1.6K Ohms purpose is.
I would love to know because I don't see it on the $50 robot other than as part of the list.
Thanks for the response.
Offline Dont_Taz_Me_Bro
« Reply #4 on: October 02, 2009, 01:50:45 AM »
Pretty sure the 1.6 kohm resistors are for your photoresistor sensors.
http://www.societyofrobots.com/schematics_photoresistor.shtml
Offline Pierre
« Reply #5 on: October 02, 2009, 03:48:56 PM »
Agree
     Thanks and thank you for linking the tutorial.  I am reading over and over the $50 robot and never saw that link.
     Gracias Dont_Taz_Me_Bro
