Author Topic: $50 robot battery pack and charger question  (Read 2161 times)
Offline woolysheepTopic starter
  • Quack
« on: July 23, 2008, 01:29:07 PM »
Hey everyone,
Just a quick question about battery packs.  I saw some other posts about how you need the proper connectors on a charger for battery packs and was just wondering if this combination (charger, converter, battery pack) will work or if I am completely on the wrong track.
This is the charger:
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1931
Was also wondering what the product option pertaining to that charger means.
And here is the battery pack:
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=495
Here is the connector:
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1332
Thanks, I am a beginner at this so the more explanations, the better.  :)
One more thing, just wondering if this is a good battery charger for individual batteries, it has all the features and is Smart:
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1652
Thanks again.
Dan
Offline pomprocker
Re: $50 robot battery pack and charger question
« Reply #1 on: July 23, 2008, 02:13:08 PM »
1. Go to CVS buy a package of 4 AA NiMH batteries that comes with the wall charger
2. Find a place to buy another single AA NiMH battery
3. Go to radio shack and buy a 5 AA battery holder
This will give you a 6v NiMH battery, a charger, and the option to charge/use them individually.
plus you don't pay shipping.
edit:  you can put any connector on the battery holder that you want to use.
« Last Edit: July 23, 2008, 02:14:19 PM by pomprocker »
Offline bulkhead
« Reply #2 on: July 24, 2008, 12:33:00 AM »
all-battery products are cheap because most of them are just low cost, entry level units with less development, testing, and product support than other "name brand" products.  The chargers may not be as reliable as you may want.  That said, a battery is a battery.  If you do order use one of their codes like "tenergydeals" or such (just google it) to save $.
You can solder whatever connectors you want or even just use alligator clips (not recommended though).  If you do replace the connectors be careful to cut ONE battery lead at a time so as to not short the battery.
If you're just looking for AA type batteries you can just get them anywhere locally.  That is, if your robot isn't using powerful motors requiring high output batteries, you don't need to invest in a good set of batteries and charger.
Offline pomprocker
« Reply #3 on: July 24, 2008, 01:09:29 AM »
just to clear this up...
AA is a size.
a type would be like NiMH or Alkaline.
Offline zack
« Reply #4 on: July 24, 2008, 05:40:19 AM »
I totally agree with pomprocker. A standard AA battery pack means you can use it for your camera, remote, whatever once you are done playing with your bot.
Offline pomprocker
« Reply #5 on: July 24, 2008, 09:51:08 AM »
just FYI a single AA NiMH battery is 1.2 volts, a single AA alkaline battery is 1.5volts. So 4 alkalines equals 6 volts, and 5 NiMH equals 6volts.
« Reply #6 on: July 24, 2008, 10:10:48 AM »
I used to use AA NiMH batteries on my smaller robots , but now I use NiMH battery packs with high amount of amperage . AA NiMH is usually like 1500 mAH , while I use at least 3000mAH on my battery packs.
Offline pomprocker
« Reply #7 on: July 24, 2008, 10:32:08 AM »
the one i got from tenergy is like 2300mah, and it was like $11
« Reply #8 on: July 24, 2008, 10:33:15 AM »
got two of those  ;D
Last post September 09, 2007, 09:21:30 AM
by HDL_CinC_Dragon
Last post March 18, 2008, 03:46:17 PM
by pomprocker
Last post April 11, 2008, 12:17:23 PM
by superchiku
Last post October 05, 2008, 10:11:24 AM
by ArcMan
