Author Topic: Temperature sensor?  (Read 2196 times)
Offline BANETopic starter
  • E=roboticsC^2
Temperature sensor?
« on: July 23, 2008, 05:58:01 PM »
Hello, I was just testing out my dual H-bridge and its getting pretty hot (not dangerously hot) :D, not because of overload or anything, its just its nature :D.  So I have two micro fans that I'd like to install from radio shack that i want to use.  I want to make a circult that has a temperature sensor so I can ether turn on the fans from my microcontroller or the H-bridge gets to hot (H-bridge takes priority :))
Does anyone have a cheap temp sensor or an idea how to hack a digital out/inside environment sensor from walmart?  I all ready have the one from walmart and it runs on two AAA batteries.
Any Ideas?
Bane
  • E=roboticsC^2
Re: Temperature sensor?
« Reply #1 on: July 23, 2008, 06:12:03 PM »
I like this one :)
http://www.sparkfun.com/commerce/product_info.php?products_id=8257
However, after looking at the price, i'm beginning to look into hacking :P
Bane
Offline bulkhead
« Reply #2 on: July 24, 2008, 12:22:03 AM »
Offline pomprocker
  • E=roboticsC^2
« Reply #4 on: July 24, 2008, 03:27:07 PM »
thanks, can a make my own temperature probe from digikey?   Is the reading device called a "Thermistor"?  I have a digikey catalog that has a bunch of them :P
BWT temperature between 50 to 300 F, or how ever high a L298 can get
Bane
Offline bulkhead
« Reply #5 on: July 24, 2008, 05:25:06 PM »
You can get this Parallax sensor off digikey for less: http://www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/CategoryID/49/List/0/Level/a/ProductID/84/Default.aspx?SortField=ProductName%2cProductName although it doesn't have a temperature "probe" that you can put on something you want to measure in particular (a)lthough you might be able to get away with letting the IC itself contact the h-bridge's heat sink.  These sensors have a digital output.  Some (I think the one I linked before) you can even program a temperature threshold so that it will switch something on if the temperature exceeds it (no need for a microcontroller).
If you want to build your own, just get a thermistor (resistance varies as a function of temperature) and an ADC to read the value, although this would require a microcontroller.
Offline Luco
« Reply #6 on: July 25, 2008, 08:49:23 PM »
Maxim DS18B20 Temperature Sensor
Its free, they give samples  :)
Also if you are using Codevision compiler for AVR they provide functions so its very easy to use.
Few month ago I got 2 of those sensors, external clocks, memory chips, and 2 iButtons.
  • E=roboticsC^2
« Reply #7 on: July 26, 2008, 05:15:27 PM »
dumb question :P; you have the pay for shipping for free samples right?  Also, do you have the register or something with the vendor?
Bane
« Reply #8 on: July 26, 2008, 05:26:21 PM »
I'd just run the fan continuously - much easier than dealing with a sensor (or paying for it, too).
But if you want to save power or keep noise low or something, just command it to turn on only when your motor is turned on.
usually no
Usually yes. And they've called me occasionally, too.
  • E=roboticsC^2
« Reply #9 on: July 28, 2008, 07:07:53 PM »
sweet ;D, I just requested one and i got an e-mail saying its already shipping :)  Its really hard not to be greedy though :P.  Heres something, it requires that you list what company your with...... well i'm not ordering for the company i work for so i just put "none".......... :D  Does anybody check this or does a computer handle everything?
Bane
Offline Luco
« Reply #10 on: July 31, 2008, 08:17:54 PM »
I think its automatic unless you are trying to sample expensive parts, then it says someone has to approve it.
Last post August 15, 2009, 01:39:01 AM
by benji
Last post March 21, 2009, 02:23:09 PM
Last post September 23, 2010, 12:12:24 AM
by galannthegreat
Last post November 03, 2010, 01:03:03 PM
by bhsmith
