Author Topic: MicroRaptor Begins  (Read 8057 times)
Offline JonHylandsTopic starter
MicroRaptor Begins
« on: January 16, 2007, 07:20:47 AM »
Hi everyone,
So, I finally got my hands on a Bioloid kit, and have started construction. You can see the whole project here:
http://www.bioloid.info/tiki/tiki-index.php?page=MicroRaptor
Specifically, click on "MicroRaptor Construction" for pictures of what I currently have built.
- Jon
Offline jsbarone
Re: MicroRaptor Begins
« Reply #1 on: January 16, 2007, 09:51:27 AM »
Wow!  That's an incredibly interesting concept.  That's what I'd like to create eventually.  Can you take detailed notes and pictures so that the community can learn from this project?  That would be awesome!
  • Helpful? 172
« Reply #2 on: January 16, 2007, 10:07:38 AM »
From webpage: I'm hoping that MicroRaptor will be able to take longer strides without falling over because it will use a 5-axis IMU to help maintain balance.
I especially want info on that IMU :P
Im planning on making my own biped run. In my head it makes sense on how to do it . . . but it might be harder than I imagine it to be. What expected speed do you aim for? One of the problems Im having though is isolating the IMU from the vibration and shock caused from running . . . Ill probably add some energy absorbing springs to the legs, not really sure yet . . .
I seriously start my biped in May when I have time, but for now Ill dream :D
« Last Edit: January 16, 2007, 12:48:41 PM by Admin »
« Reply #3 on: January 16, 2007, 12:46:17 PM »
Absolutely, I will be taking detailed notes and pictures, and publishing on my site...
- Jon
« Reply #4 on: January 16, 2007, 12:50:17 PM »
Im planning on making my own biped run. It my head it makes sense on how to do it . . . but it might be harder than I think. What expected speed do you aim for? One of the problems Im having though is isolating the IMU from the vibration and shock caused from running . . . Ill probably add some energy absorbing springs to the legs, not really sure yet . . .
Admin,
I don't know if MicroRaptor will be able to run - I hope it will. In turns of using the IMU, my plan is to let it learn to figure out how to use it. The IMU will present a certain pattern while it is moving, and if it is successful at the movement, the expected IMU pattern becomes part of that movement sequence.
- Jon
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #5 on: January 16, 2007, 01:32:31 PM »
kinda like how a person learns how to walk...then maybe how to run?
« Reply #6 on: January 16, 2007, 02:36:06 PM »
Jesse,
Exactly. In my mind, there is no reason to "program" in responses to sensors - the robot should be able to learn that stuff by (controlled) experimentation. Eventually, once it gets past a certain point, it should be able to learn independently.
The only limitation on whether MicroRaptor will be able to run versus walk will be due to limitations in the actuators.
- Jon
« Reply #7 on: January 25, 2007, 08:11:26 AM »
And on that topic, MicroRaptor's first step...
http://www.bioloid.info/tiki/tiki-index.php?page=MicroRaptor+Movies
I've also got some information about the tools I'm writing to do this:
http://www.bioloid.info/tiki/tiki-index.php?page=MicroRaptor+Screenshots
- Jon
  • Helpful? 172
« Reply #8 on: January 25, 2007, 08:36:19 AM »
impressive! :)
i see you redesigned the neck . . . decided not to have vertical head/tail motion?
any thoughts on how to fix that serious wobbly/vibrating issue?
how long did it take for you to tweak the motions for that first step to work?
just a thought . . . you dont have the cam and battery and electronics on it yet . . . you should put 'simulation weights' in respective places on your walker, otherwise you may find yourself redoing the walking sequences when you finally do load the weights onto it . . .
« Reply #9 on: January 25, 2007, 09:28:14 AM »
Admin,
I removed the pitch servo for the neck, because it was having a hard time holding up the head sticking straight out, and I haven't even added the cameras yet, so there was no chance.
The vibration comes from the servos attempting to keep a specific position. I have been fiddling with the compliance parameters and torque settings to find a happy medium between having them squeal and having them chatter.
The motion tweaking only took a few minutes, maybe 10. Writing the tool that let me do that took several hours.
I'm just working on the software tools right now, so I'm not worried about the dynamics of the system changing once I add the batteries/electronics/cameras. Everything I'm doing right now with respect to movement sequences is throw-away, not the least because eventually it will have an IMU onboard, and it will use that to tweak the sequences itself to maintain balance.
- Jon
« Reply #10 on: January 25, 2007, 11:22:28 AM »
awwwww I can't watch widows media files....... :-\
So you are using an atmega128 connected over wifi and doing your processing on a remote
desktop? Are you using somekind of relational database (sql or the like) to keep you learning?
And also on you sensor query concept, are you implementing this as a kind of controller and when certain conditions exist you start up a thread that does something about the sensor query untill resolved? Then overlay the outputs of these threads in a subsumption like architecture? or am I way off base?
« Reply #11 on: January 25, 2007, 12:31:35 PM »
Jesse,
I put up a MOV version of the movie.
I don't have the wifi set up yet - the wifi module is on its way out west to my brother, who is going to write the SPI interface to it. However, I'm still doing my processing on my laptop, and its connected to my ATmega128 interface board via USB for now.
Right now, I keep the robot definition in a sort-of object database on disk - eventually, when it gets complicated enough, I'll start using a real OO database, but for now I can just serialize the robot into a file without any trouble.
The sensor query will be implemented pretty much as you describe. The sensor query will get execution time each cycle to do matching against current sensor readings, and if there is a match it will execute the trigger associated with that event. The event handler will be overlaying in some cases, or completely overriding in others, the outputs from the "standard" movement controller.
The nice thing about this mechanism is that you can implement a wide range of interesting behaviors with it, including balance, landmard based navigation, and goal satisfying.
- Jon
« Reply #12 on: January 25, 2007, 04:20:03 PM »
I think you could work out a pretty good architecture if you talked to your brother.
Here's my idea. (and I'm a gumstix nut because they are small but you could do this with any embedded PC)
So you do the same thing with the Atmega128 but feed it to a gumstix (which means you switch the ATmega128 from sparkfun
to a robostix but it should be fairly portable) as for the IMU processing and the ballance you can leave that on the Gumstix because it would be faster there. For the vision part and higher AI you can add straight up 802.11bg with the gumstix wich should get you faster high level AI while keeping the lower level AI functions running without the latency of the SPI interface.
Another pro is that you can run your vision through the gumstix which will alow the Atmega to react to commands much quicker and not have to push as much data through.
just my crazy talk though....
« Reply #13 on: January 25, 2007, 04:37:35 PM »
Well, the original plan was to have a gumstix onboard, and use that as the "brain". However, after talking to some people, and playing around with my gumstix/robostix, I decided to switch to a PC-based brain, with a high speed wifi connection to the robot. The robostix can talk to the Bioloid bus at 1.0 Mbps, but unfortunately when you're running at that speed, you can't also run the second UART at 921 Kbps, which is as fast as most serial wifi links will go. So, we looked at the DPAC wifi module, which optionally comes with an SPI port instead of a UART. The SPI port on the DPAC module can talk at 1.0 Mbps, but because its a slave SPI device, the micro-controller you talk to it with has to be a master SPI device.
My brother, who gave a lot of design input into the robostix, told me that the robostix can't do master SPI, so we looked at another ATmega128 module, and quickly settled on the one from Sparkfun because it is small, cheap, and brings out all the pins.
The gumstix does not have anywhere the memory, processing power, or storage available to do the level of "brain" control that I want to do. The way I will have it hooked up (once my brother gets the wifi module code done), I will have a straight-through high speed low latency wireless connection to the Bioloid bus, running at 1.0 Mbps. I will be using wireless cameras for stereo vision, which will feed back into separate USB digitizers for video processing. Since my laptop is a Core Duo, I've got an extra core sitting there doing nothing while my Smalltalk brain code runs, so it might as well be doing vision processing.
The ATmega128 will only be handling the actuators on the bus (servos, plus any custom actuators I build) and simple low-rate sensors like IMUs and touch/pressure. Video will be going back to my PC on its own wireless channel.
- Jon
« Reply #14 on: January 25, 2007, 07:14:03 PM »
ahhhh makes sense to me..... ;D
« Reply #15 on: February 02, 2007, 04:33:24 PM »
Speaking of a IMU, I have one that I'm playing with right now with MicroRaptor (not the final one that will go on the robot, though).
It will be interesting to see how the data it produces will help. I wrote a little graph package so I can view log results in a visual form from my GUI, and it shows some really neat results.
The IMU I am using right now is this one:
http://www.sparkfun.com/commerce/product_info.php?products_id=754
- Jon
Offline annoyin_kid
« Reply #16 on: February 02, 2007, 10:49:28 PM »
wow that is amazing. are you doing that for your job/university or just for fun? are you self funded or you got some big company sponsoring you?
are those servos special ones because they dont look like the ones i normally see?
anyway that is amazing.
« Reply #17 on: February 03, 2007, 08:04:23 AM »
This is a hobby for me, so I'm just doing it for fun, although I treat it like a research project. I am a professional software developer though, and get paid for doing software development (not robotics software, unfortunately).
I am self funded for the most part, although I've formed a relationship with an AI group in the US (http://www.huv.com/blog/2006/12/brain-engineering.html) who are providing me with hardware to play with in exchange for doing design and development work for them.
I got this relationship going with this lab because they and I both wanted to do the same thing (high speed wireless control of a Bioloid robot), and I knew how to do it and they didn't.
The AX-12s are special servos, in fact they are downright amazing.
http://www.crustcrawler.com/products/AX12/index.php?prod=63
- Jon
  • Helpful? 172
« Reply #18 on: February 03, 2007, 08:37:43 AM »
"The AX-12+ actuator is a continuous rotation motor with feedback support"
Are they really fully continuous?!
"These little beauties (AX-12+) report angular position, angular velocity, and torque load, and more."
Do you know how it reports these things?
« Reply #19 on: February 03, 2007, 09:15:50 AM »
The AX-12 can switch from a 300 degree positonal servo to a full-rotation gearmotor by setting a software parameter.
It uses a half-duplex one-wire serial daisy-chained bus to communicate with the controller, so each servo is plugged into the one beside it. The bus runs at 1.0 Mbps, which as it turns out is doable by any of the ATmega chips. Because it is a one-wire bus, you have to cross the Tx & Rx pins, but as long as your software is doing the right thing, that isn't a problem. The servos are powered by 9.6 volts, and each has two 2-pin connectors (signal, ground, power).
Each AX-12 has a unique ID on the bus, and you can send messages (commands) to individual servos, or all the servos at once (broadcast). Each servo has a table of RAM and FLASH locations that correspond to parameters, including: sensed position, sensed speed, sensed load, desired position, desired speed, maximum torque, minimum torque, and various compliance parameters.
You can also set many settings in each servo, including temperature limits, rotation limits, and a bunch of other things.
The real kicker is that the AX-12 has 222 oz-in (16kg-cm) of torque at 9.6V.
I've got software (freely available) that runs on an ATmega128, and acts as a pass-through from your PC's serial port at 115,200 baud to the AX-12 bus, running at 1.0 Mbps. My brother is working on a piece that interfaces an ATmega128 (or a 168) to both the AX-12 bus and to an SPI wifi module, so we will be able to get a full 1.0 Mbps wireless connection from a PC to a 20-servo robot.
- Jon
Offline annoyin_kid
« Reply #20 on: February 03, 2007, 04:28:11 PM »
wow that is a nifty servo you got there. it must have been expensive because you brought so many of those servos.
« Reply #21 on: February 03, 2007, 04:41:08 PM »
The individual servos sell for $45.
The kit I have sells for $900 (and it comes with 18 of the servos), but I didn't buy it - it is one of the pieces of hardware I have on loan from the Brain Engineering lab.
I'm probably going to buy my own in a couple months, depending on how financing goes.
- Jon
« Reply #22 on: February 09, 2007, 07:30:21 AM »
Thought I would post an update here - I have a few movies of MicroRaptor walking now...
- Jon
« Reply #23 on: March 16, 2007, 06:20:11 PM »
Well, things have been moving along, although at the moment MicroRaptor has been "mutated" to a humanoid form.
I just finished building a 6-axis IMU that is tiny (1.15" x 0.75") and hooks into the same Bioloid bus the AX-12 servos are controlled on.
http://www.bioloid.info/tiki/tiki-index.php?page=6-Axis+Bus+IMU
- Jon
Offline Jess
« Reply #24 on: March 27, 2007, 07:17:42 PM »
I've been looking at the Bioloid kits myself, nice to see someone experimenting with the kit instead of just building the pre-designed robots.
Your MicroRaptor looks excellent!
Jess.
