Author Topic: Axon Blackfin Power  (Read 2542 times)
Offline vidamTopic starter
  • Robotronics.org
Axon Blackfin Power
« on: July 25, 2008, 10:02:36 PM »
Can i have separate power supply for the blackfin and the axon. For example I have a 9 Volt battery connected to the blackfin. To the axon I have a 6 volt battery to BAT.
Is this ok when using the Blackfin and Axon together?
Re: Axon Blackfin Power
« Reply #1 on: July 25, 2008, 10:08:54 PM »
Yeap. Just make sure grounds are common. The uart on the axon has rx/tx/ground, so that ground pin is all you need for a common ground.
I just ran two wires from the unregulated ground/power bus on the Axon and directly plugged that in to the Blackfin.
  • Robotronics.org
« Reply #2 on: July 25, 2008, 10:11:53 PM »
that sounds like you only had 1 power supply to the axon and jumpered it to the blackfin from the unregulated ground/pwr bus?
« Reply #3 on: July 25, 2008, 10:19:12 PM »
yeap, easier that way.
but you can do either.
Last post June 29, 2008, 02:31:22 PM
by hgordon
Last post July 27, 2008, 09:02:25 AM
by vidam
Last post July 27, 2008, 08:51:47 PM
Last post September 30, 2008, 06:58:41 AM
by Penth
