Author Topic: simple navigation with stereo vision  (Read 8029 times)
Offline popayseamanTopic starter
« on: July 28, 2008, 03:01:28 PM »
These are three videos showing my robot doing simple, rule based navigation using stereo vision and wheel encoders only
[youtube]GTAe7WfMrbI[/youtube]
[youtube]ca6m7kUAglI[/youtube]
[youtube]9mknQOJgVlk[/youtube]
Offline airman00
Re: simple navigation with stereo vision
« Reply #1 on: July 28, 2008, 04:16:15 PM »
awesome bot
can you please provide more details on the software and hardware setup?
Offline BANE
  • E=roboticsC^2
« Reply #2 on: July 28, 2008, 07:30:01 PM »
thats a laptop right?  where did you get the vision sensors or what ever you used?
bane
« Reply #3 on: July 29, 2008, 11:58:13 AM »
Most of the hardware comes from Robot Electronics http://www.robot-electronics.co.uk/index.html
All the software running on the laptop I've done by myself.
The stereo camera is a pair of Logitech Quick Cam webcams stripped of their plastic globes and housed in
an aluminium box. The original optics was also changed with a higher quality one.
Offline airman00
« Reply #4 on: July 29, 2008, 02:37:05 PM »
cool, you should document this robot and enter it in the contest here!
can u please post your source code?
Offline SeagullOne
  • Humans and Robots working together for our future.
« Reply #5 on: July 30, 2008, 01:25:39 AM »
Yes! I, too, would love to see your source code! What programming language did you use? C? C++? Python?
Loren
I think the chauffeur did it.
He did.
« Reply #6 on: July 30, 2008, 07:07:41 AM »
I've registered for the competition, so I will be releasing a tutorial about my robot soon.
It's all written in C/C++
« Reply #7 on: August 16, 2008, 08:09:29 AM »
hm, it seems I won't be able to prepare a tutorial in time for the competition, just not enough time and too busy at work.
some time later may be
« Reply #8 on: October 09, 2008, 03:47:05 PM »
Navigation with a map
[youtube]c6r-oMy1A0E[/youtube]
« Reply #9 on: October 10, 2008, 07:22:47 AM »
Whoa nice job! Now, make it faster and go from your room to your fridge! (serious :P)
Also, perhaps write up a tutorial or documentation on it? ;D
Offline airman00
« Reply #10 on: October 10, 2008, 07:49:30 AM »
please write up documentation or a tutorial! You would definitely win the SoR Robot Contest
« Reply #11 on: October 10, 2008, 12:29:56 PM »
he he, that's the ultimate goal, yes  :)
but I will have to make it also distinguish between Carlsberg and Fosters ;D
and hopefully make it capable of frying eggs as well  :D
I promise I will write a tutorial at some point, it's just much more fun working on the above things than on documentation
Offline SciTech02
  • Life's but a green duck with soy sauce. -MegaHAL
« Reply #12 on: October 10, 2008, 06:29:26 PM »
Very nice job!  The map looks like it was made by the robot itself (based on its stereo cameras).  If it is, you could develop a simutaneuos localization and mapping program (SLAM), that would be really cool.  8)
Now if the robot had voice recognition and text-to-speech abilities, it would be the ultimate robot IMO...
Check out the Evolution Robotics, ER1 robot, and ERSP Resource Page: http://www.societyofrobots.com/member_tutorials/node/336
Offline andd64
« Reply #13 on: October 12, 2008, 02:46:55 PM »
did you use roborealm or it is strictly all your code?
where did you get the higher quality optics from?
very nice job btw!!
Offline hgordon
  • Helpful? 7
« Reply #14 on: October 12, 2008, 07:48:09 PM »
You will find a lot of detail on Bob's work here -
    http://code.google.com/p/sentience/
and here -
    http://sluggish.uni.cc/sentience/sentience.htm
He's running his own code, much of which is found on his code.google.com pages.
Surveyor Corporation
  www.surveyor.com
« Reply #15 on: October 13, 2008, 10:59:51 AM »
no, I wrote all the code myself, from the low level USB comms and camera capture routines to the exploration strategy, including the stereo vision engine
you can get the optics from here if you reside in the UK or from a similar electronics store elsewhere in the world
http://www.maplin.co.uk/Module.aspx?ModuleNo=19631
it's the wide angle lense (150 deg)
if you also get this particular model of Logitech webcams
http://www.amazon.co.uk/Logitech-Quickcam-Messenger-camera-colour/dp/B000JK8RWY/ref=sr_1_1?ie=UTF8&s=electronics&qid=1223916932&sr=8-1
then it's simply a matter of unscrewing the original optics and screwing in the new lense
Unfortunately, due to the small imaging sensor of the Logitech webcam and after correcting the considerable barrel distortion from the wide angle lense,
the effective FOV is reduced to only about 90 deg, which is still not too bad actually
Offline andd64
« Reply #16 on: October 14, 2008, 12:29:10 PM »
The webcam link (amazon one) has a model number of 961608-0914.  I live in Canada, and the ones i found have a model number of 961608-0403 (e.g http://www.ca.buy.com/prod/Logitech_QuickCam_Messenger_Webcam_Black_CMOS_USB_White_Box/q/loc/59573/202989027.html).  Will this be a problem to change the lens to a 2.1 mm wide angle lens?  Or would I have to get the same model number as yours?
« Reply #17 on: October 15, 2008, 02:24:47 AM »
I think you should be ok with that one. By the way, one thing I forgot to mention in my previous post is that you also need to remove the infra red filter (it's a square piece of reddish glass) from the back of the original optics and glue it to the new optics. I haven't tried it but if you leave it out you may be able to end up with a sort of an infra red camera :)
« Reply #18 on: October 19, 2008, 05:23:14 AM »
Not really, because it doesn't remove visible light from the image. It'll be an infrared cam at nighttime however :P
« Reply #19 on: October 20, 2008, 05:54:30 AM »
yep, it will be a strictly night-time robot then :D
Offline thomasWong
« Reply #20 on: February 20, 2009, 06:43:09 PM »
That is great job !!. Do u mind to post your source code ?
Last post July 10, 2007, 05:20:29 AM
by JonHylands
Last post November 24, 2010, 05:09:54 AM
by sinista
Last post August 04, 2011, 02:26:08 PM
by fosk
Last post December 11, 2012, 09:20:48 PM
by sdk32285
