Author Topic: Ping pong ball launcher  (Read 12784 times)
Offline CritchleyTopic starter
« on: January 18, 2007, 11:40:34 AM »
For my latest robot, I hope to have some kind of ping pong ball launching mechanism. Think of a tennis serving machine, except with ping pong balls. How exactly would this work though? Maybe I would use a pneumatic mechanism?
Any thoughts?
Offline trigger
Re: Ping pong ball launcher
« Reply #1 on: January 18, 2007, 01:24:37 PM »
Any thoughts?
How about a spring-loaded armature that ejects the ping-pong ball when a pin blocking the armature is displaced, and the armature is moved back to the starting position by a servo? The pin could be servo-controlled for fully-automatic use or manually controlled (e.g., a trigger).
Offline gamefreak
  • Robo-Enthusiast
« Reply #2 on: January 18, 2007, 09:45:44 PM »
well since im just starting on my none kit robot i would think a solonoid maybe. Have a pipe with a ramp on the end lead into the shooting chamber, then fire the ping pong after so many seconds or when a button is pressed.
Offline Brandon121233
« Reply #3 on: February 14, 2007, 10:07:44 PM »
I think it depends on how far and with how much force you intend to launch it with. You stated a tenis ball seving machine, so if you plan on it going over 20 or so feet (pretty far for a ping pong ball) I would suggest using a pneumatic device which would use like a paint ball CO2 tank with an electronic auctuator attached to some some 1.5 inch pvc pipe. For the lower end  (under 10 feet) some sort of servo activated spring launcher would be best. If you have any specific questions just email me at [email protected] and I'll try to get back to you as soon as possible.
        —Thomas Edison
Offline Hal9000
« Reply #4 on: February 15, 2007, 03:39:03 AM »
As above, it would be a matter of how far you wanted them to go. Being ping pong balls, they are normally far too light to do anything really far with, right?
This guy, as you can see, uses two big fast spinning wheels to chuck out the balls
This also looks good for the slower, but probably stronger (and not continuous fire)
http://mindstorms.lego.com/eng/inventions/invention.asp?id=%7BF59E3BB0-57C4-E211-96EE-598AF8DB26A7%7D&SlotN=2&galleryid=337
And, um, theres this weird looking thing
http://www.amazon.com/Ping-Pong-Ball-Launcher-Butterfly/dp/B000KC1L74
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #5 on: February 15, 2007, 05:58:25 AM »
http://www.youtube.com/watch?v=RSCPLHfdpSA
the guy said it looked like an ice cream maker! :D
Offline Hal9000
« Reply #6 on: February 15, 2007, 07:22:43 AM »
I cant hear anything on this PC because it has no speakers.
Lolz at the ice cream maker. Bet it tastes really yummy where HE gets it from! :)
There is a much more fun version of this (although cant find it at the moment) of the two wheels throwing cds. It looked lethal  :o
Offline Sam_Charette
« Reply #7 on: February 15, 2007, 12:29:29 PM »
I would go with the spinning wheels myself.  It's probably the easiest and cheapest way, and it works well.
The LED Massacre continues.  Death count is now 5
Offline ed1380
« Reply #8 on: February 15, 2007, 04:24:13 PM »
How about a robot actuated air potato cannon, but smaller so it can fire a ping pong ball. and with a co2 tank, so you don't have to pump it up everytime.
Last post December 18, 2007, 07:51:55 AM
by reSpawn
Last post January 22, 2008, 07:51:22 PM
by airman00
Last post July 21, 2012, 01:59:07 PM
by John_Milton
Last post July 21, 2012, 03:17:01 PM
by John_Milton
