Author Topic: Building first RC car robot  (Read 2647 times)
Offline RCbotbuilderTopic starter
  • Itachi......will pay.
« on: August 03, 2008, 09:25:07 AM »
I am now building my first RC car robot. this is pretty cool because this is the next step up from both of my old mindstorm robot kits.
Re: my own topic
« Reply #1 on: August 03, 2008, 09:31:39 AM »
i am going to use a servo controller to controll it. then you may ask HOW IN HECK ARE YOU GONNA DO THAT! first, from a laptop a wireless signal will go to the controller. then when the conroller trys to make a servo move i will use that power coming out to trigger a transistor. that transistor connected to staight to the battery will make the biger moters move
"i shall fail but i will fail with style!" :D
Re: Building first RC car robot
« Reply #2 on: August 03, 2008, 09:33:21 AM »
you'll need a special H bridge that converts servo pulse to motor speed and direction
another method that I've seen in some cars is to have the servos turn switches and pots to control the larger motors
« Reply #3 on: August 03, 2008, 09:51:44 AM »
What is a h bridge and may one build one? and please go easy on electronics because im only 12
« Reply #4 on: August 03, 2008, 10:05:17 AM »
google it
you'll get plenty of results . Then after you got more specific questions post em here!
« Reply #5 on: August 03, 2008, 10:14:35 AM »
do i have to use one?
and also i need help with all those wires for steering
can you help me with that? im testing with my power supply right now actually!
« Reply #6 on: August 03, 2008, 10:16:59 AM »
do you want speed control on your robot or just fully forward or fully backward?
« Reply #7 on: August 03, 2008, 11:42:13 AM »
i dont want speed control
« Reply #8 on: August 03, 2008, 12:30:13 PM »
Offline Gertlex
  • Helpful? 23
« Reply #9 on: August 07, 2008, 09:45:09 AM »
Or build a mechanical switching device that uses a servo.  And another servo to a rheostat to control speed (though burning out rheostats is pretty easy, too)
I've done this same general project using bluetooth:
http://www.societyofrobots.com/robotforum/index.php?topic=1672
http://www-personal.umich.edu/%7Eerelson/BluetoothCar.html
Two pics of the motor polarity switch: http://www-personal.umich.edu/%7Eerelson/BluetoothCar.html#31
I
« Reply #10 on: August 19, 2008, 10:55:29 AM »
ive just torn apart the controller and for stering it has 6 electrical contacts with a slider that conects two contacts as the bar is pushed
example:
Last post May 12, 2010, 05:02:32 PM
by amando96
Last post December 02, 2010, 04:53:41 PM
by french guy
Last post March 25, 2011, 02:36:28 PM
by hoohoohama
Last post August 21, 2011, 12:11:56 AM
by 123laurens
