Author Topic: Arduino PS2 Controller  (Read 13141 times)
Offline JSH21Topic starter
« on: August 03, 2008, 10:12:58 PM »
Hi can you connect an Arduino Diecimila board to a ps2 controller so you can control the servos you have attached to it?
Offline sonictj
  • Helpful? 11
Re: Arduino PS2 Controller
« Reply #1 on: August 04, 2008, 03:37:58 AM »
I just checked the arduino forum and found this http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1203744779.
you could also do what I do, which is use  Glovepie to emulate keyboard presses to control the arduino.  http://carl.kenner.googlepages.com/glovepie
works with wiimotes ,the ps3 sixaxis and a few other controllers I think.
« Last Edit: August 04, 2008, 03:44:57 AM by sonictj »
« Reply #2 on: August 04, 2008, 11:11:57 AM »
Cool thanks very much :)
Offline sonictj
  • Helpful? 11
« Reply #3 on: August 04, 2008, 01:15:36 PM »
if you use glovepie you will want to map out buttons with both a key and a enter press.
*example
when the wiimote's "a" button is pressed keyboard "a" and keyboard "enter" are emulated. key.enter is a part of the code, because the arduino software requires it to send data.
*note look over golepie's syntax.  It is VERY easy to code in but its a bit different from wiring.
GLOVEPIE
key.a + key.enter = wiimote.a
key.b + key.enter = wiimote.b
arduino code
// wiimote led on off control
#define led 13
char cin(){
  while(true){
    if(Serial.available() > 0){
      return Serial.read();
void setup(){
Serial.begin(115200);  //this is the baud I typically use
pinMode(led,OUTPUT);
void loop(){
char command = cin();
     if(command == 'a') digitalWrite(led,HIGH);
else if(command == 'b') digitalWrite(led,LOW);
« Last Edit: August 04, 2008, 02:02:02 PM by sonictj »
Offline madsci1016
  • Helpful? 43
« Reply #4 on: June 25, 2010, 04:38:20 PM »
For those who find this thread through Google, I have created a fully functional PS2 Controller Arduino library.
http://www.billporter.info/?p=240
Enjoy.
Last post December 19, 2007, 12:55:55 PM
by Mega
Last post January 16, 2009, 10:07:32 PM
by Kirk
Last post May 08, 2011, 10:17:42 PM
by jdeck
Last post December 16, 2012, 10:19:01 AM
by MrWizard
