Author Topic: solve this problem please? it serves as my project can you help me?  (Read 1490 times)
Offline ac1006Topic starter
the problem goes like this..........
Make a program that can convert number  "1" to number "one" do it until "3000",
if it is above 3000 display "out of range"
the output will be this:
press any number below 3000 : 215
result : two hundred fifteen
Re: solve this problem please? it serves as my project can you help me?
« Reply #1 on: August 10, 2008, 05:40:36 AM »
Hello,
I had a similar program in my speech recognition for Chives , my butler robot, when I wanted him to say the current temperature out loud. I didn't want to record numbers from 1 - 100 because that was too annoying. Instead you do the following :
Get the raw number ( e.g. 250)
Divide up the number into its components ( 200 , 50 , 0 )
Now you just speak 200, then 50 , then skip zero and say nothing
Please note you have to program exceptions to this rule , like numbers between 10 and 19.  You would have to manually record those , since eleven follows no rule. But from 14 to 19 , you could say the singles digit ( four ) and then the tens digit ( teen ) .
For the above 3000 thing thats simple, just a simple IF THEN statement
What  programming language are you using and is this for PC or microcontroller?
Last post June 22, 2008, 09:44:27 AM
by nick
Last post December 12, 2010, 01:22:04 AM
by Nasser_Abu Dhabi
Last post June 18, 2011, 02:56:51 AM
by Mike11
Last post February 09, 2013, 11:15:34 AM
by jwatte
