Author Topic: Motor Library for Arduino Question  (Read 3980 times)
Offline DudekillerTopic starter
« on: August 10, 2008, 08:12:49 PM »
For the motor library for Arduino to work, do I really need to get the motor/servo protoshield for the Arduino board?
Offline sonictj
  • Helpful? 11
Re: Motor Library for Arduino Question
« Reply #1 on: August 17, 2008, 12:33:49 AM »
which library and shield are you referring to?
either way you cannot just hook up a motor directly to an arduino or any other controller unless there is an h-bridge/motor driver connected to the i/o pins in question
the arduino i/o pins are only rated for (i think) ~40ma anything more than that will possibly fry that pin.
If you tell me specifically what you're intending to do I can suggest hardware solutions too.
« Last Edit: August 17, 2008, 12:46:27 AM by sonictj »
Offline newbie
« Reply #2 on: August 27, 2008, 12:07:55 AM »
hi there, ;)
i am using this motor driverhttp://www.ladyada.net/make/mshield/index.html, for a mini servo and using this libraryhttp://www.arduino.cc/playground/ComponentLib/Servotimer1.
i want to program my physically modified servo to turn 360 degree continuously (with backward and forward movement), how to program it? :-\
Offline sonictj
  • Helpful? 11
« Reply #3 on: August 27, 2008, 11:52:21 AM »
all you have to do is use the write function with either 180 or 0 example: servo.write(180);
you can say servo.detach() to stop the servo from moving sense your servo is modified.
Last post August 24, 2010, 07:47:26 PM
by wlewis
Last post April 09, 2009, 12:52:19 PM
by Razor Concepts
Last post April 14, 2010, 10:29:39 AM
by Rindis
Last post May 08, 2011, 10:17:42 PM
by jdeck
