Author Topic: find "K  (Read 2546 times)
Offline robotaTopic starter
find "K
« on: August 15, 2008, 11:07:17 AM »
Hallow,
I have a mechanism and I want to find the "K" of this mechanism because I want to build a block diagram for control
How I can find this "K" ?
Offline ArcMan
  • Mmmm... Plasma
Re: find "K
« Reply #1 on: August 15, 2008, 08:51:12 PM »
This could be like "20 questions".
Let's see...
Is the mechanism a spring?
Seriously though, we will need some information about the mechanism and what sort of control you wish to impart on it.
Offline JesseWelling
  • Only You Can Build A Robot!
Re: find "K
« Reply #2 on: August 15, 2008, 11:05:37 PM »
Do you mean the K gains as in PID?
Re: find "K
« Reply #3 on: August 17, 2008, 11:38:09 AM »
mechnism could be 4/5/6 bar linkage
k=k gain
Offline Trumpkin
Re: find "K
« Reply #4 on: August 17, 2008, 05:06:20 PM »
« Last Edit: August 17, 2008, 05:07:18 PM by Trumpkin »
Robots are awesome!
Re: find "K
« Reply #5 on: August 19, 2008, 07:45:37 AM »
I will glad to receive more replies
robota
Offline paulstreats
Re: find "K
« Reply #6 on: August 19, 2008, 05:45:23 PM »
I presume that you mean Kinematic measurement (as in solid state Kinematic Viscosity).
It would be extremely difficult to help you without any further information on your mechanism such as joint links, link lengths, stop points, expected end result etc...
Without knowing what the state of non movement and the state of the desired end result is expected to be, the link calculations cannot be given.
I would advise to research how kinematic movement is represented in computer programming, you will find that there are many variables that affect the mathematics. It would likely be easier to program a representation of your model into a computer alongside a kinematics tutorial program, where you would be able to see the output that you want and also get a moving visual representation of your device moving within its constraints.
