Author Topic: Soldering Iron Heat?  (Read 1958 times)
Offline MarkBrownTopic starter
« on: August 15, 2008, 03:47:54 PM »
I received an adjustable heat soldering station a year or so ago.  I never really learned what tempurature to use for what.  Before I start soldering away to build the circuit for the $50 robot, I was hoping someone could give me a tip as to which to use.
Thank you,
Mark Brown
It is human nature to confuse genious with insanity
http://marksproject.blogspot.com/
Offline pomprocker
Re: Soldering Iron Heat?
« Reply #1 on: August 15, 2008, 05:07:50 PM »
« Reply #2 on: August 15, 2008, 05:41:30 PM »
Thank you very much.  That is exactly what I was looking for.
Mark
Offline Brandon121233
« Reply #3 on: August 15, 2008, 09:59:27 PM »
Well I do almost everything with surface mount so I use solder paste and a griddle, but if I am soldering I usually check the data sheets of the components and check what the maximum soldering temperature is then set my iron to or below that. If I'm having trouble getting a nice joint then I will raise the temp like 10 degrees or so.
        —Thomas Edison
« Reply #4 on: August 15, 2008, 10:33:47 PM »
Excellent advice, thanks.  I have experience in soldering, but it is mostly made up of wiring Deans connectors to batteries or wires to motors and such.
« Reply #5 on: August 17, 2008, 09:50:06 PM »
I tend to find hotter is always better.
The one exception is that hotter usually increases wear and chances of damage to your soldering iron tip.
« Reply #6 on: August 19, 2008, 06:54:49 PM »
who care about the tip, they cost like $1 you can find those in cracker jack boxes, most of the smaller SMD stuff is really sensitive to heat too like MCU's, FETs and voltage regs, the data sheets are usually very conservative but that stuff will fry.
        —Thomas Edison
« Reply #7 on: August 20, 2008, 04:44:01 AM »
I meant the really nice tips :P
I know its counter-intuitive, but the longer you keep the iron on a part, the more the part will heat up. So with a really hot iron, you can get the job done much faster. My rule of thumb is 'hot enough to solder in under 3 seconds' for the hard stuff and under 2 for the rest.
Last post January 13, 2008, 07:39:37 PM
by gamefreak
Last post March 05, 2008, 09:18:13 AM
by Trumpkin
Last post June 01, 2008, 02:12:00 PM
Last post October 04, 2008, 01:02:01 AM
by izaktj
