Author Topic: $50 Robot Help - Led Flash  (Read 1958 times)
Offline MarkBrownTopic starter
« on: August 18, 2008, 11:28:27 PM »
Last night I had the robot working.  Today moved all the parts to a new chasis that I have been working on for it.  After hooking everything back into the circuit board, the only response I get when I hook up the power is a very brief LED flash.  I have had this happen before and it turned out that I had a little fleck of solder creating a short.  This time though I am not able to find a short.  I have tried this without any cables plugged in, just servos and just sensors.  I figured something might have happened to the programming so I reprogrammed the chip with no errors.  I tried again after reprogramming and received the same result.  I have also tried different batteries.
I am starting to go a little crazy.  Does anyone have any advice?
Mark
It is human nature to confuse genious with insanity
http://marksproject.blogspot.com/
Re: $50 Robot Help - Led Flash
« Reply #1 on: August 19, 2008, 12:10:51 AM »
I did some further testing and my robot is now working.  The led is still flashing or flickering, but the robot is working.
Now I get to have some fun modifying the code a bit.  The robot begins to turn when the light changes, but only briefly before going forward again.  I assume this is due to the algorithm where the light is the same for both sensors.  Probably a delay change should fix it.
At anyrate, it is working now.
Mark
Offline pomprocker
« Reply #2 on: August 19, 2008, 12:29:40 AM »
post your code.
you can use the LED like you would with print statements in a program for easy debugging,
put the LED_on; inside of a function or loop so that you know when it gets to that line of code, the LED can in a sense help you step through code.
« Reply #3 on: August 19, 2008, 01:05:52 AM »
I am still using the original code provided by Admin in the tutorial.  I will post any code changes I make if that is what you mean.
Mark
Last post June 28, 2010, 07:36:17 AM
Last post July 01, 2008, 10:30:58 PM
by silent069
Last post December 18, 2009, 08:47:40 AM
Last post June 19, 2011, 07:15:39 AM
