Author Topic: Heat sinking ICs  (Read 1862 times)
Offline JoeTopic starter
Heat sinking ICs
« on: January 23, 2007, 07:07:09 PM »
I plan on using a couple of L293E ICs for motor drivers. Everything I've read suggests heat sinking, and I can understand why, with all that current going though a little IC circuit. But how do you heat sink a DIP IC?
I have many guesses. On top? Sounds wrong. Plus the L293 documentation notes that there are 4 ground pins in the center (pins 5, 6, 15, and 16 in a 20 pin package) for heat sinking purposes. Where exactly do you put the heat sink and how is it attached?
Re: Heat sinking ICs
« Reply #1 on: January 24, 2007, 08:51:13 PM »
i looked up the datasheet for the L293E here:
http://www.datasheetcatalog.com/datasheets_pdf/L/2/9/3/L293E.shtml
on the first page it says 'use the four center pins to conduct heat to the printed circuit board' :P
this type of IC isnt designed for heatsinks, and instead uses the pins to get rid of heat
Last post May 21, 2010, 08:15:22 AM
by Hawaii00000
Last post May 24, 2010, 07:47:07 AM
by TrickyNekro
Last post October 01, 2010, 10:58:42 PM
by cyberfish
Last post November 23, 2011, 02:13:35 AM
by adaboy
