Author Topic: UART on any pin  (Read 3089 times)
Offline airman00Topic starter
UART on any pin
« on: August 23, 2008, 07:53:14 PM »
I have a question on UART.
Why is UART limited to certain pins on the AVR?
Back in my PIC days ( like 3 months ago , lol  ) I was able to achieve TTL serial communication on any pin . It seems that with the AVR UART is only on certain pins. Well serial is just a combination of 1 and 0 , so shouldn't serial be possible on any output pin?
Can someone clear this up for me ?
Thanks,
Eric
Re: UART on any pin
« Reply #1 on: August 23, 2008, 08:33:08 PM »
hardware UART vs software UART . . . the previous is more accurate, faster, and less computationally expensive.
the latter is called 'bit banging'
Re: UART on any pin
« Reply #2 on: August 23, 2008, 08:40:31 PM »
oh thanks for clearing that up
with hardware UART does this "run in the background" or something like that?
Re: UART on any pin
« Reply #3 on: August 23, 2008, 09:13:08 PM »
Someone correct me if I'm wrong here, but I believe the buffer does. But it's only like 1 byte, if I remember correctly.
Re: UART on any pin
« Reply #4 on: August 23, 2008, 09:26:42 PM »
is there some function in the AVRlib for bit-banging?
Re: UART on any pin
« Reply #5 on: August 23, 2008, 09:48:03 PM »
If you google around, you can find source code to do it. No built in function, however.
Offline Kirk
Re: UART on any pin
« Reply #6 on: September 02, 2008, 10:23:31 PM »
The Arduino environment has a bit bang send and recieve serial on any pin that I have used.  It could be hacked to run under gcc.
Kirk
Offline pomprocker
Re: UART on any pin
« Reply #8 on: September 03, 2008, 04:35:57 AM »
Actually now that I think about it, I seem to remember seeing AVRlib having a software UART.
Offline Kirk
Re: UART on any pin
« Reply #9 on: September 03, 2008, 06:23:38 AM »
Oh I forgot about AVR USB   firmware only USB
http://www.obdev.at/products/avrusb/index.html
Offline pomprocker
